stock map sensor and boost.
Old Jun 15, 2015 | 06:19 AM
MethHeadCrx's Avatar
Default stock map sensor and boost.
so with a stock map sensor my understanding is if you boost over 12 psi it will burn out. well my car spiked 17 the other day and now is missing on top end. does this have to do with the fact that its not reading now and not pulling enoug timing under boost ? normal driving is fine
Old Jun 15, 2015 | 10:15 AM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: stock map sensor and boost.
https://honda-tech.com/honda-civic-d...sting-3002401/
Try again.
Old Jun 15, 2015 | 01:36 PM
what do you mean try again as in it is fine and something else is wrong
Old Jun 15, 2015 | 01:51 PM
NotARaCist's Avatar
Read the rules. You failed to give us a large amount of required information. We aren't here to play guessing games for you.
Old Jun 15, 2015 | 02:35 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Originally Posted by NotARaCist
Read the rules. You failed to give us a large amount of required information. We aren't here to play guessing games with you.
FTFY
Old Jun 15, 2015 | 03:06 PM
wantboost's Avatar
Who is Mr Robot?
Eh, I'll bite
Stock map sensor won't read pressure over 11psi. Yes you can kill the sensing components if you expose them to too much pressure. However if you can't appropriately tune for higher pressure then that spike more than likely damaged more than a map sensor
Old Jun 15, 2015 | 03:36 PM
NotARaCist's Avatar
And now that your bad thread has been moved to FI, here's a new set of rules for you to read.
https://honda-tech.com/forced-induct...round-2164678/
Old Jun 15, 2015 | 05:31 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
OP - You most likely blew your engine from being untuned in the region you boosted to. Time to give the engine a full once over. I personally haven't ever fried a stock MAP sensor from boosting over its limit. Ahhh, the FMU days... LOL!
Old Jun 15, 2015 | 09:23 PM
TheShodan's Avatar
Moderator
Ah yes.. 12:1 Rising Rate FMUs and Missing link "check valves".. ah, the days when turbocharging a honda was SOOO simple.
Old Jun 17, 2015 | 03:18 AM
NVturbo's Avatar
O.G. triple O.G.
So simple with GOD'S GIFT TO MAN..... APEXi SAFC
LOL
Old Jun 17, 2015 | 11:10 AM
TheShodan's Avatar
Moderator
LOL
Oh yeah... the V-AFC/ S-AFC / 450cc DSM injector "hack".. Those actually were pretty decent back then if you didn't mind staying in closed-loop. Ran rich as hell, but the **** worked like a charm!
Old Jun 17, 2015 | 12:28 PM
Aradin's Avatar
Premium Member
You blew the welds on the intake bud.
Old Jun 19, 2015 | 03:22 AM
NVturbo's Avatar
O.G. triple O.G.
it works fine, on the drive to the dyno shop.
krugozor
Feb 21, 2011 08:38 PM
Ldo
Oct 9, 2010 03:35 PM
SnailedEG
Jan 28, 2010 12:52 PM
GoHybrid
Mar 29, 2009 06:13 PM
B16Drag
Jan 25, 2006 06:59 AM
