stock map sensor dependibility?
Old Jul 6, 2009 | 04:46 PM
Honda4life777's Avatar
Icon2 stock map sensor dependibility?
I have heard that if your boosting around 9-10 psi, that the stock map sensor wont last long and that you should upgrade to a 3 bar sensor even though you may not be boosting past the 11psi. I just need to know if i should get a 3 bar map sensor for my build at 9 psi of if I can just leave the stock one on. Thanks for the help
Old Jul 6, 2009 | 05:02 PM
GSROWNSU's Avatar
Default Re: stock map sensor dependibility?
I had my car tuned on 10psi with the stock map for a few months and never had a problem. Boost cut was definitely set at 11 psi for assurance. Tial 44mm ftw Held 10psi all day and never spiked once.
Old Jul 6, 2009 | 05:30 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
"if" your staying at 9psi you dont need to upgrade......that's if.
Old Jul 6, 2009 | 06:53 PM
so the stock map sensor doesn't need to be replaced if only 9 psi. and i wont have to worry about is failing after awhile from it seeing boost?
Old Jul 6, 2009 | 09:00 PM
b20beast83's Avatar
it wont fail from boost
TooSmooth
Jan 24, 2011 06:19 AM
Ldo
Oct 9, 2010 03:35 PM
SnailedEG
Jan 28, 2010 12:52 PM
hondamn1320
Apr 3, 2008 05:54 AM
teddy_dc2
Aug 8, 2006 07:51 PM
