How much boost can stock MAP sensor read?
Old Oct 7, 2010 | 09:10 AM
Ldo's Avatar
Ldo
Default How much boost can stock MAP sensor read?
Can the stock OBD0 CRX MAP sensor see up to 10psi?
Old Oct 7, 2010 | 09:19 AM
D16SiHatch's Avatar
Default Re: How much boost can stock MAP sensor read?
stock sensor is good for just over 10 psi. if you are running that close to the max though it would probably be a good idea to upgrade to a gm or omni power sensor that can register more psi.
Old Oct 7, 2010 | 09:31 AM
roadsqueegy95's Avatar
yep. good for right around 10-11psi.
Old Oct 7, 2010 | 12:27 PM
Ldo's Avatar
Ldo
Thanks. I max out at 8psi.
Old Oct 7, 2010 | 12:34 PM
Schister66's Avatar
Man U FTW
Its a 1,8 bar map sensor. One thing to remember when dealing with map sensors is that they account for 1 bar of atmospheric pressure; therefore, your map will read 0,8 bar of positive boost pressure (11,6 psi). I would not get within a half a psi of it's limit though. As they're not supposed to see boost pressure from the factory, they do tend to vary in their ability to read pressure correctly.
Old Oct 7, 2010 | 01:14 PM
boostedls92's Avatar
i ran 11psi on a stock map senor , but a month later up graded to a gm 3 bar
Old Oct 7, 2010 | 01:24 PM
welfarepc's Avatar
mine too. datalog would never show above 8.65psi.
Old Oct 8, 2010 | 12:11 PM
EsotericImage's Avatar
Retired Moderator
Xenocron.com has sensors cheap
Old Oct 8, 2010 | 07:16 PM
blackeg's Avatar
dont forget to set a boost cut
Old Oct 9, 2010 | 10:04 AM
Axix24's Avatar
run the plug n play hondata map sensor... Problem fixed...
Old Oct 9, 2010 | 03:35 PM
blackeg's Avatar
not always that easy, depending on his situation he could need a retune and that costs bucks and not really needed if he is running 8ish psi.
the last car i tuned was a boosted b16, 8 psi off the wastegate stock map sensor on neptune. i set the boost cut to 10psi to give 2 psi for creep and whatnot on colder nights
krugozor
Feb 21, 2011 08:38 PM
hatchBK4life
Feb 3, 2010 12:08 PM
Honda4life777
Jul 6, 2009 09:00 PM
Beer
Jun 19, 2002 11:44 PM
HiGhCaM
May 11, 2002 11:40 PM
