LS/VTEC turbo
Old Apr 22, 2004 | 12:02 AM
2 point 0's Avatar
Default LS/VTEC turbo
my friend has a LS/VTEC turbo block that he's selling. block has darton 84mm sleeves, JE pistons, crower rods. little **** like bolts and all that. my question is, the block was built for ls/vtec. i want to buy it but i only want to do LS turbo. will i run into any problems? when doing ls/vtec, is anything special done to the block itself? i know the head needs to be drilled for the line. other than that, i dunno.
Old Apr 22, 2004 | 09:38 AM
2 point 0's Avatar
Default Re: LS/VTEC turbo (2 point 0)
bump
Old Apr 22, 2004 | 12:43 PM
2 point 0's Avatar
thanks for the help
Old Apr 22, 2004 | 03:11 PM
torr's Avatar
the block itself doesn't go through any changes. if you want to do a ls turbo than just put an ls head on it. make sure the compression of the pistons are compatible to run boost.
kbear
Jul 29, 2010 07:31 AM
silverdc2integra
Sep 28, 2009 11:17 AM
TurBoTeG
May 8, 2007 02:02 AM
TougeCoupe
May 29, 2005 05:58 PM
