Stock block quiestion...
Old Jul 7, 2004 | 07:56 PM
crazyimport's Avatar
Default Stock block question...
Quick question
what psi are you guys running on your stock b16's ???
I have a b16a2 with itr valvetrain and rc 440cc injectors... whats the max safe psi you guys would take it to and redline ?
Old Jul 7, 2004 | 08:01 PM
94gsr4dr's Avatar
Default Re: Stock block question... (crazyimport)
psi is irrelevant, hp is what matters and i would aim for about 280-300whp with a good tune.
Old Jul 7, 2004 | 08:22 PM
Default Re: Stock block question... (94gsr4dr)
so your saying i can run 30 psi on stock block as long as im hitting 300 hp
Old Jul 7, 2004 | 08:28 PM
MachAF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyimport &raquo;</TD></TR><TR><TD CLASS="quote">so your saying i can run 30 psi on stock block as long as im hitting 300 hp </TD></TR></TABLE>
Yes. But that would never happen. Its all about mass flow. A t25 10 at psi will create say 230whp. A t67 @ 10psi will create 300whp. These are just estimates not facts.
the amount of torque (horsepower) will determine how long the motor lasts. Power creates heat, more power = more heat = harder on engine.
its not the air being forced into the motor that hurts it, its the combustion pressure from the increased density of the air.
Old Jul 7, 2004 | 09:07 PM
SiRkid's Avatar
with your turbo you could probably run around 12-13 psi before you reach a power limit...your injectors will probably hold you up a bit aswell as the stock map sensor as it only is good till 11 psi..
so id put a cap on it at 10 psi and leave the car alone!
Old Jul 7, 2004 | 09:24 PM
Default Re: Stock block question... (SiRkid)
map sensor is being replaced with gm 3 bar....
i think im going to run 12 psi
GetawayInMoscow
Aug 7, 2007 01:04 AM
ACrite3404
Jun 18, 2007 10:15 PM
boostedcivicsir
Nov 26, 2005 08:44 PM
sPaRk'iT
Jun 12, 2004 11:19 PM
wm5holla
May 1, 2003 07:48 AM
