Stock block b16 boost ?
Old May 31, 2014 | 01:06 PM
mx125cc's Avatar
Default Stock block b16 boost ?
Hello, how mutch boost do you guys think a b16 w/ stock sleeves will handle ?. Already running on 22psi
Old May 31, 2014 | 01:19 PM
Dark_Teg's Avatar
Default Re: Stock block b16 boost ?
A lot of variables here. Efficiency plays a huge role when you get into high boost. If your turbo is running out of its efficiency range past 22 psi adding more boost may just skyrocket EGT's and blow a sleeve from detonation. If your turbo has more breath you may be able to make more power but I would say you are on the edge in this scenario.
Old May 31, 2014 | 02:05 PM
mx125cc's Avatar
The turbo has no problem going 30+psi, im just wondering how high i can go w/o cracking a sleeve, the motor itself is far from orginal but i still have the stock sleeves std. Bore, i have a block guard though.
Old May 31, 2014 | 06:56 PM
wantboost's Avatar
Who is Mr Robot?
Block guards cause more issues than they "fix"
we can't give you any advice till we have a full build sheet for your motor, the kinds of fuel you run, what kind of power you're making now, how much you want to make, etc.
it might not even be possible to make any more power with your current turbo or fuel limitation, so turning up the boost wouldn't serve a purpose. this is why we need details, not just some vague post.
Old May 31, 2014 | 08:21 PM
justYncredible's Avatar
It's wU to the sOLdiEr!
About 9,001psi because it's over 9,000!
Old May 31, 2014 | 08:48 PM
wantboost's Avatar
Who is Mr Robot?
But seriously.. normally a gradual increase in cylinder pressure won't break anything, such as the gradual increase from turbocharging or other forms of forced induction, at least not within reason...
It's the rapid/uncontrolled increases that break things, such as what happens during detonation, knock, etc.
Old Jun 1, 2014 | 05:42 AM
mx125cc's Avatar
here's something
CP 9.0.1
Manley H beams
eagle foged 4340 cranck
cometic head gasket std thickness
arp head studs
bc stage 2 turbo cams
bc springs + titanium retainers
supertech block guard
acl bearings
orbit oil pump
rc 1000cc injectors
obx intake w/ 70mm TB
"ram horn" Exhaust manifold
38mm external wastegate
Holset hx40 turbo, with 14cm2 exhaust housing from hx35
Fmic, 2,5" pipeing
megasquirt ecu
msd 6al blaster with coil
zetronix wideband
Aem E85 320lph pump
the fuel i use is 98oct, and i was thinking of E85 instead
Old Jun 1, 2014 | 10:48 AM
here's something
CP 9.0.1
Manley H beams
arp head studs
acl bearings
orbit oil pump
rc 1000cc injectors
Fmic, 2,5" pipeing
megasquirt ecu
zetronix wideband
Aem E85 320lph pump
What hp are you trying to accomplish? If your octane is that high I would just use that, just my opinion.
Old Jun 1, 2014 | 05:25 PM
wantboost's Avatar
Who is Mr Robot?
Well e85 (assuming it's actually 85% ethanol which it really isn't due to blending variations) is 105 octane (r+m/2). your 98 octane is simply a Ron or Mon measurement, not our r+m/2 method so technically it's octane is lower.
you can push a Holset hx40 well beyond 22psi but the limit here is your fuel. on your 98 you're probably close to the chemical limit of the fuel.
in order to transition over to e85 you need an e85 fuel pump, e85 compatible fuel line (the stock stuff gets eaten by ethanol) and much larger injectors since e85 requires more fuel for a given power output compared to straight gasoline or the e10 that's common pump gas in America.
Coolero
23
Dec 10, 2009 02:55 PM
97grnrs
Jan 6, 2008 07:07 PM
crxrider07
Dec 20, 2007 10:48 AM
ttracing03
Apr 1, 2006 02:43 PM
pelotudo
Feb 3, 2003 10:23 PM
