Stock b18b1 Boost Range?????
Old Nov 6, 2011 | 08:46 PM
  #26
AZITRCLONE's Avatar
Default Re: Stock b18b1 Boost Range?????
You get what you pay for!
Old Nov 6, 2011 | 09:46 PM
  #27
10psiLsEf2's Avatar
Thanks guys.
Ill look into a brand name.(used) of course.
What is a good brand.
and also im doing all this in my 1991 civic so do i need to get 4 wire o2 for wideband
Old Nov 6, 2011 | 09:50 PM
  #28
sc34dc4's Avatar
Originally Posted by 10psiLsEf2
Thanks guys.
Any wideband O2 you buy comes with the sensor. If you're looking for a used turbo the most common ones you will run across is Garrett or Precision. Both are great units.
Old Nov 6, 2011 | 09:56 PM
  #29
10psiLsEf2's Avatar
Oh i c
how do i wire a wideband? on a obd0 car
Thanks for all the info sc34...
Old Nov 6, 2011 | 10:20 PM
  #30
racebum's Avatar
precisions entry line, like the SC34 can be had for $539 now a days. please guys, don't cheap out on that. as most of us know, **** turbos cost you more in the long run
Old Nov 6, 2011 | 10:24 PM
  #31
sc34dc4's Avatar
Oh i c
The Aem Uego is a self contained unit. They are like $180 new $150 used. All you need is a power and ground wire hooked up.
Old Nov 6, 2011 | 10:58 PM
  #32
terbear4god's Avatar
i went a year boosting daily on a 100% stock bottom end b18a1 at 315whp 220trq revving too 8200rpm and i still believe it would be running if i diddent drive threw a big a** puddle tuned by the best at english racing tho...right now im boosting 353whp 254trq revving 8200 daily just has the upgraded nippon pistons and arp rod bolts(acl race bearings)
its ALL in the tune
Old Nov 7, 2011 | 05:42 AM
  #33
nealnanoHX's Avatar
JDM Sport turbos are made in the USA as are CXRacing so they last a lot longer than the average Ebay China turbo. But they still are not as good as a Garrett.
Old Nov 7, 2011 | 05:44 AM
  #34
nealnanoHX's Avatar
Originally Posted by slowturbocx
Do your RESEARCH, I'll BUILD fast cars!
Cant build a fast car with out a goal and researching needed parts to make it all work together. All the top racers do tons of R&D before doing anything. A well planned build will result in a well balanced car and motor. Just my 2 cents.
Old Nov 7, 2011 | 06:03 AM
  #35
LightningTeg's Avatar
Community Builder
LoL Where is your source for THAT information?
Old Nov 7, 2011 | 09:24 AM
  #36
nealnanoHX's Avatar
Source is the suppliers JDM Sport and CXRacing as well as using these turbos in cars in the past. I agree the GodSpeed turbos suck and are cheap Chinese, but the other 2 are a pretty good deal for the quality and money. I would never use a cheap turbo on one of my cars and JDM Sport has given me years of use with no issues.
Old Nov 7, 2011 | 09:39 AM
  #37
sc34dc4's Avatar
^^^ YOU'RE A FU-KING IDIOT! PLEASE JUST STOP TALKING. YOU CLEARLY DON'T HAVE A CLUE AS TO WHAT YOU'RE TALKING ABOUT.
Old Nov 7, 2011 | 12:17 PM
  #38
racebum's Avatar
pretty much, this is why yours lived and many of the others done just the same fail
btw, how did a puddle kill the engine? did you not have the air filter up high?
Old Nov 7, 2011 | 12:31 PM
  #39
rich7777's Avatar
Now that is one famous worldwide saying that applies absolutely everywhere...
Old Nov 7, 2011 | 02:25 PM
  #40
nealnanoHX's Avatar
Dude I would not have said it if it was not true, no need to be an a$$. I have used several JDM Sort turbos on many builds and never once had an issue with a turbo failing or boost creeping. I would not touch one sold by anyone else on ebay as the failure rate is pretty scary. JDM Sport is making a good name for themselves Project Car Magazine has been looking into their parts recently and testing them as well. I also have JDM Sport upper control arms on my current car and have no issues and camber adjustment is great. I have only used 2 turbos from CXRacing and both of those have been on the street daily abused and some track time for 2-3 years now, but since I have only ever used 2 I can not say too much for them.
Here are the ones I have had good results with
http://www.ebay.com/itm/JDM-SPORT-T3...ht_3360wt_1139
http://www.ebay.com/itm/New-T3-T4-T0...#ht_3290wt_952
Here are some to stay well away from
http://www.ebay.com/itm/T3-T4-Hybrid...#ht_1073wt_952
http://www.ebay.com/itm/CXRacing-T3-...item43aabaa720
http://www.ebay.com/itm/T3-T4-T04E-T...item4cefdb413e
Granted the best way to go is a Garrett, Turbonetics, Precision, Greddy as they are the industries tried and true turbos and have lived for over 100K miles. While I will be the first person to speak up against using a China turbo there are some that do well if money is limited. But IMO you really should not be building a turbo kit if you are too worried about money.
Old Nov 7, 2011 | 04:59 PM
  #41
Rickcrx's Avatar
My B18b made 268whp 232tq with 450cc with room.
Old Nov 7, 2011 | 05:08 PM
  #42
Community Builder
Old Nov 7, 2011 | 06:40 PM
  #43
10psiLsEf2's Avatar
thanks guys. ill look into a used arrett.
Old Nov 9, 2011 | 03:49 PM
  #44
10psiLsEf2's Avatar
If my motor were to give out were would it go?
Were are Ls weak spots when it comes to BOOST
Old Nov 10, 2011 | 05:46 AM
  #45
puddle went over the bumper and started over the hood turbo sucked up ALOT...hydrolocked and seized ended up bending 1 rod
but i do believe the ls weak point is more of the sleeves iv seen quite a few cases were the sleeves themselves cracked but still all being in the tune..
personally i would tell you too max were i was bout 315whp-320whp on 92oct on a 100% stock bottom end it gives room too be daily'd and used
oh and keep your revs below 8k i was at 8200 but the last 200rpm was worthless
Old Nov 10, 2011 | 08:28 AM
  #46
Community Builder
Sleeves are the same as a B18c. Ring lands are always weakest link
Old Nov 10, 2011 | 10:35 AM
  #47
you449's Avatar
rc550cc should do the job for daily driving buddy
Old Nov 10, 2011 | 12:08 PM
  #48
AROD's Avatar
i went 12.4@110 on stock LS, ebay turbo, Crome, and DSM 440cc injector on 22" slicks 10psi of boost , stock map sensor.
Old Nov 10, 2011 | 11:10 PM
  #49
10psiLsEf2's Avatar
nice numbers
what chassiss?
complete interior?
What rpms laucn
Ludeist
Oct 25, 2007 12:26 PM
smileycvc
Jul 30, 2007 05:05 PM
greygoose87
Feb 23, 2007 08:50 AM
X2BOARD
Jun 18, 2003 10:14 AM
Nikos
Apr 14, 2002 08:00 PM
