Stock B16 + SC61 = 7psi @ ????RPM
^Could u work that out?? LOL
I got a Stock B16a2 with a SC61 and log mani, 3" full exhaust.
When should i expect to hit 7psi ( set by WG )??
Seems to be around 5300rpm, this sound normal? Would have thought a little lower.
Anyone with a simular setup have any bhp/tq figure or trap times?
Thanks
Thanks
Re: Stock B16 + SC61 = 7psi @ ????RPM (JordanCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93CX »</TD></TR><TR><TD CLASS="quote">SC61 seems to spool very slowly, why is this?</TD></TR></TABLE>
because it is a big turbo
7 psi on such a small engine, so late in the powerband, means it's going to fall off like hell whenever you shift. Unless you're busting the hell out of every gear trying to break your transmission.
You need 16-18 psi minimum to be happy with that turbo.
Man U FTW
Why the hell do people chose turbos that are 4 times larger than what they need....if you want a car that makes power from 6500 rpm and on, then this is a great setup...if you want something that doesn't suck, look around a little more before chosing a turbo.
An SC61 can support 550+whp and you're not going to be near its efficiency range. Most people dont understand how to decide on turbos and rather than learning, just follow a bandwagon. That's why the GT35r is so popular...even on setups where it is less than 1bar. If you're looking for a fun setup on a street car, get a 3bar map sensor, a good tuning software, a GT3251b and run 14psi...you'll make a good amount of torque, have full boost before 4k rpm, and have power through redline.....AND still spend less money than the SC61
if you want to look into that last option more, PM me and we'll talk...
Hang fire!!
I did state in a previous post that 'the motor will be built, hence the sc61'. I have a 1.7L motor being built that will be running 1.5bar.
I understand there will be alot less lag with a GT BB turbo, and if/when i upgrade i will be going down that route.
Man U FTW
Re: (JordanCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JordanCivic »</TD></TR><TR><TD CLASS="quote">I understand there will be alot less lag with a GT BB turbo, and if/when i upgrade i will be going down that route.</TD></TR></TABLE>
Another common mistake...there isn't a significant amount less lag w/ the GT-R series, they are generally better engineered turbos that have a lot lbroader efficiency range. The turbos are designed around the BB CHRA...dont start thinking that it is the BB CHRA that does all the work. Converting a turbo to a ball bearing center cartridge WILL NOT improve spool, it will only help in transient response.
Moderator
Re: (MidwestAutoWorks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MidwestAutoWorks »</TD></TR><TR><TD CLASS="quote">How would this sc61 spool on a 2.3 liter</TD></TR></TABLE>
Better than 1.7litre with no stroke to the displacement...
Re: (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 »</TD></TR><TR><TD CLASS="quote">Why the hell do people chose turbos that are 4 times larger than what they need....if you want a car that makes power from 6500 rpm and on, then this is a great setup...if you want something that doesn't suck, look around a little more before chosing a turbo.
if you want to look into that last option more, PM me and we'll talk...</TD></TR></TABLE>
i like your sales technique . i guest YOU'RE offering the turbo cheaper than a SC61. because i have never seen ANY BB turbo cheaper than $800 new
Man U FTW
Re: (tony413)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony413 »</TD></TR><TR><TD CLASS="quote">
i like your sales technique . i guest YOU'RE offering the turbo cheaper than a SC61. because i have never seen ANY BB turbo cheaper than $800 new</TD></TR></TABLE>
The GT3255b is not a ballbearing turbo. Ballbearing GT series turbos are denoted GT-R. Also, you dont need a BB CHRA to spool fast...people really misunderstand the benefits of them
Re: (Schister66)
Is it correct that this GT325xb is similar to an SC61 with an older spec turbine wheel, or is that something else? I can't keep it all straight.
Re: (Schister66)
The GT3255b is not a ballbearing turbo. Ballbearing GT series turbos are denoted GT-R. Also, you dont need a BB CHRA to spool fast...people really misunderstand the benefits of them</TD></TR></TABLE>
i dont use BB turbos because the cost for me do not outweight the benefits.
