2 step (searched)
Old Jul 4, 2007 | 12:58 PM
scuffywin's Avatar
Default 2 step (searched)
what do you guys set your two step at?? like 5500?? oh 12lbs of boost ???whp
Old Jul 4, 2007 | 01:30 PM
GetawayInMoscow's Avatar
Default Re: 2 step (scuffywin)
I set it at 9500 rpm and I build 42 psi on a GT42R
On a stock B16 BTW....
Old Jul 4, 2007 | 01:34 PM
RCautoworks's Avatar
Default Re: 2 step (GetawayInMoscow)
A lot of it will depend on your setup, some people can grab traction at a higher rpm range then others. No sense to put it like at 8 grand if you can't gain traction, know what I mean ?
Old Jul 4, 2007 | 06:19 PM
scuffywin's Avatar
Default Re: 2 step (RCautoworks)
yea i see what you mean but i was trying to get a consensus to see what a good starting point would be for test and tune
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GetawayInMoscow &raquo;</TD></TR><TR><TD CLASS="quote">I set it at 9500 rpm and I build 42 psi on a GT42R
On a stock B16 BTW....</TD></TR></TABLE>
ha
Old Jul 4, 2007 | 09:20 PM
mike93eh2's Avatar
1000 rpms here and antilag is set to build 47psi at the line.
Old Jul 5, 2007 | 02:47 AM
scuffywin's Avatar
Default Re: 2 step (mike93eh2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93eh2 &raquo;</TD></TR><TR><TD CLASS="quote">1000 rpms here and antilag is set to build 47psi at the line. </TD></TR></TABLE> hey what do you know another idiot hey guys thanks for the info
Old Jul 5, 2007 | 03:10 AM
KeyserSoze's Avatar
What they are saying is it is not a question with a real answer. Different setups are going to be different. Also every engine is different as well. Try different settings and after a few tries you should be able to dial it in.
Also, your question is quite difficult to understand. Try re-wording it so that people can more easily understand what you are trying to ask them.
If I remember correctly you need to set your fuel cut, ign cut and retard rev. Then again I have an aem unit and have never tried it on another ems/piggy back system.
Remember what RCautoworks said as well. If your suspension/tires can't handle dropping the clutch @ 5-6k rpm then why even try?? GL.
Old Jul 5, 2007 | 03:57 AM
93supercoupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scuffywin &raquo;</TD></TR><TR><TD CLASS="quote"> hey what do you know another idiot hey guys thanks for the info</TD></TR></TABLE>
its tuff luv on HT, but they mean well.
Old Jul 5, 2007 | 09:55 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: 2 step (93supercoupe)
t3t67ho, 84mm b16, msd 2 step.
8200 building 8-10 psi depending on the air for the day.
anything less it fell on its face. no anti lag. i am trying to leave at 5-5500 this year. if i get my car done. he hee.
Old Jul 5, 2007 | 01:16 PM
scuffywin's Avatar
Default Re: 2 step (boostedcivicsir)
hey guys thanks for the responses i am going to try it at a couple of different rpm points and see which ones work best
VTEC_PRODUCTION
14
May 30, 2007 08:58 PM
DB1_559
Oct 20, 2005 12:05 AM
Aespooncivic
Apr 18, 2005 12:59 AM
POWERINTEGRA
Aug 5, 2004 07:42 PM
JjuuN R
Dec 4, 2003 12:12 AM
