Stealthmode Oil line kit
So I was wanting to order an oil line kit but I'm not exactly sure which kit to order. On their website they have 2 options for T3 turbos
T3 Turbo Oil Line
kit uses a 1/8 thread size for the oil inlet. The drain flange from center to center mounting bolts measures 50.8 mm.
T3 Turbo Specia Turbo Oil Line
kit uses a 1/4 thread size for the oil inlet. The drain flange from center to center mounting bolts measures 50.8 mm. It also uses different mounting bolts for the drain flange. This has only been found on new turbos thus far.
I assume by thread size they are talking about the diameter of the tapped hole? I contacted them and they will not respond. I have a Precision SC61 if anybody knows which one I need or of another better oil kit I would appreciate it, thanks.
T3 Turbo Oil Line
malubawla
Jan 25, 2007 04:05 PM
