need help to get correct oil line kit for a garrett t3/to4e turbo
hey i have a Garrett 57 trim t3/t04e with a .63 a/r
where should i buy my oil line kit from, i know that shealthlines, fast-turbo sell them
can someone please send me a link for the proper kit for my turbo.....thanks alot
Man U FTW
Re: (RedEj8)
14B (Tdo4h) Turbo Oil Line
14B uses a M12x1.25 thread size for the oil inlet. The drain flange from center to center mounting bolts measures 38mm. This kit does not come with the mounting bolts to bolt the drain flange onto the turbo. There are many different sizes used on different variations of the 14B, leaving us to choose not to carry them.
T25 Turbo Oil Line
kit uses a 7/16 thread size for the oil inlet. The drain flange from center to center mounting bolts measures 44mm.
T3 Turbo Oil Line
kit uses a 1/8 thread size for the oil inlet. The drain flange from center to center mounting bolts measures 50.8 mm.
T3 Turbo Specia Turbo Oil Line
kit uses a 1/4 thread size for the oil inlet. The drain flange from center to center mounting bolts measures 50.8 mm. It also uses different mounting bolts for the drain flange. This has only been found on new turbos thus far.
GT Series Turbo Oil Line
kit uses a 7/16 thread size for the oil inlet. The drain flange from center to center mounting bolts measures 50.8 mm. This is for the GT35r, GT28 ect turbos.
so which one is it??
T25 Turbo Oil Line
T3 Turbo Oil Line
Re: (malubawla)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by malubawla »</TD></TR><TR><TD CLASS="quote">14B (Tdo4h) Turbo Oil Line
T25 Turbo Oil Line
T3 Turbo Oil Line
so which one is it??</TD></TR></TABLE>
so which one do i buy????
T25 Turbo Oil Line
T3 Turbo Oil Line
