stage 1 turbinewheel VS stage 3
hello. i messured my turbo today and got a little dissipointed.
my turbine was a stage1 and my compressor was a S-trim (1,907"*2,75")
it is 63AR on exhaust and 60 on the comprressor.
is stage 3 better and if why? should i get one?
my setup is
b16a1
CP pistons
golden eagle rods
3" downpipe and 3" exhaust
2,5"chargepipes
63mm TB and ported intake
ITR cams
running 15psi
my setup is
b16a1
CP pistons
golden eagle rods
2,5"chargepipes
ITR cams
running 15psi
Re: stage 1 turbinewheel VS stage 3 (anton_)
hello.
what the fu..k schould i do with my turbonetics turbo. it feels like it is waaay to small
the messurments is
1,90 * 2,75 on the compressor. it should be 45 in trim, it is 60 in AR
the turbine is 1,9 * 2,28 and 63 in AR
now i am boosting 15psi
should i get a larget turbine?
regards anton
the messurments is
regards anton
Moderator
The stage 1 wheel is very small indeed for a b16 motor for something that will go higher on the upper band. I would contact turbonetics and ask to have a replacment sent. More than likely they didn't know what application you were using. Worse case scenario, sell the unit, purchase a better one.
Nextelbuddy
06-26-2004 05:38 AM
Greyout
08-07-2003 08:15 AM
BlueShadow
12-26-2002 12:28 PM
