srp 8:5:1 compression pistons fine with my setup?
Im almost finish with my build. I found a set of NEW in the box srp 8:5:1 pistons for my ls block for 200. Im gonna be running a t3/t4 57 trim turbo on an mildly built ls/vtec setup. I plan on running 16-18lbs tuned. Will these pistons be fine or should i spend retail value and buy higher compression pistons.
My setup.
Gsr head
AEBS intake manifold
AEBS 65mm throttle body
ARP Headstuds
Shaved??? im not sure how much i should yet.
Possibly port and plolished
Ls block
Oem golden eagle ls/ vtec headgasket
Stock bore SRP 8:5:1 pistons
Eagle h-beam rods with ARP rod bolts
ACL thrust washers, main bearings and rod bearings
Micropolished crank
Possibly a golden eagle block guard if it's worth it.
How much power would i possibly be looking at with this setup. And would it be fine? id like to break 350whp.
My setup.
Gsr head
ARP Headstuds
Ls block
Micropolished crank
MaxBoost
20
07-07-2003 11:50 PM
