Are these the correct pistons for my setup?
Old Jan 13, 2006 | 02:11 PM
slowteg550's Avatar
Default Are these the correct pistons for my setup?
I recently bought a block, pistons, and rods from a member here on HT. Everything he told me seems to be legit, but I have questions about the pistons.
The setup in the end will be a b18c1 head, this block that i'll list below, and a gt35 @ about 25 psi... hoping for 550 wheel horse.
Anyway the block is a Darton sleeved 85 mm b18a1. I got it, with Crower Billet steel LS Rods, and JE 85 mm pistons. The part # on the pistons is 185918 and the box says B16a3. I know the size is rigth on them, I just dont know if the rod length of the LS rods is right, and if they will work with the LS rods, LS crank, and b18c1 head?
Also, does anyone know, or know the formula to find out what the compression of these will be with a b18c1 head on the b18a block (9.0 advertised compression)
Old Jan 13, 2006 | 03:35 PM
tilt's Avatar
Default Re: Are these the correct pistons for my setup? (slowteg550)
not sure about your other questions, but here is a compression calculator:
http://www.c-speedracing.com/h...c.php
Old Jan 14, 2006 | 04:28 AM
slowteg550's Avatar
Default Re: Are these the correct pistons for my setup? (tilt)
If my calculations are right the comp ratio is like 9.3
anyone know for sure these are the right pistons for LS rods and an LS crank?
2004cobra
Jan 18, 2007 11:38 PM
x91crxsix
Jun 29, 2006 08:09 PM
agp1183
Jan 23, 2006 01:35 PM
MADEINIRAQ
Feb 26, 2003 07:15 PM
