split my electrodes' WTF
Old Oct 22, 2003 | 11:33 AM
graphic's Avatar
Default split my electrodes' WTF
i took out my ngk copper plugs..(500miles on them at 5psi of boost) heat range 7
and i noticed that all 4 of the plugs have the center electrode splite about half way down the middle...
WTF...is up with this ****...
they are gapped at .030 ..is the gap too tight???
BTW, car is a 98 prelude..
Old Oct 22, 2003 | 12:00 PM
Jared's Avatar
Default Re: split my electrodes' WTF (graphic)
are you sure they arent just V Power plugs?
Old Oct 22, 2003 | 12:10 PM
graphic's Avatar
Default Re: split my electrodes' WTF (Jared)
i'm not sure???
Old Oct 22, 2003 | 01:00 PM
ClubSiRacer's Avatar
Post a picture of the plugs... Make sure it shows the tip itself in at least one picture and the plug part number on one of them. I'm 95% sure you cant "split" the electrode...
On a side note, I had a slight problem with the car studdering from 7500rpm to 9000rpm and it was making a little less power than normal. Though the plugs only have roughly 3k miles on them, I decided to swap another set in to see if that was the problem. Uh yea... I think this picture should clear up what my problem was. (This was just today even.) Strangely, it ran fine under part throttle despite the problem. It also pulled hard as ever to about 7000rpm and then started to cut out. Needless to say, its back in prime power again. (Glad I buy plugs 40 at a time!)
"Hmm, somethings missing!" Plugs in order #4 -> #1 facing the same direction... Note #4 electrode...
Old Oct 22, 2003 | 01:16 PM
Jeff33S's Avatar
Lose something ehh?
-Jeff-
Old Oct 22, 2003 | 02:31 PM
HXMan's Avatar
Default Re: split my electrodes' WTF (jerseykid609)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jerseykid609 &raquo;</TD></TR><TR><TD CLASS="quote">thats crazy where that piece go nobody knows </TD></TR></TABLE>
Probably thru the exhaust?
Old Oct 22, 2003 | 02:38 PM
The Destroyer's Avatar
Default Re: split my electrodes' WTF (HXMan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HXMan &raquo;</TD></TR><TR><TD CLASS="quote">
Probably thru the exhaust? </TD></TR></TABLE>
wonder if he damaged the piston...
Old Oct 22, 2003 | 03:05 PM
Default Re: split my electrodes' WTF (I Need Money.)
I poked a probe in to look, the pistons look fine on the tops anyway. I'm guessing it happened under boost and was likely shot out the exhaust valve and through the exhaust itself. The car runs perfect now that I dropped new plugs in.
Old Oct 22, 2003 | 03:18 PM
Sleepin''s Avatar
Default Re: split my electrodes' WTF (ClubSiRacer)
A little detonation?
Old Oct 22, 2003 | 06:37 PM
Default Re: split my electrodes' WTF (Sleepin')
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sleepin' &raquo;</TD></TR><TR><TD CLASS="quote">A little detonation?</TD></TR></TABLE>
No, none at all... We have it tuned rich, around 11.9:1 on a wideband. I think I may have damaged it myself before installing the plug. Its impossable to tell from the picture, but it looks more like it broke off. I checked and other than average carbon buildup, the piston tops are flawless and it doesnt have any other signs of detonation.
Old Oct 23, 2003 | 06:48 AM
Sleepin''s Avatar
Hmm, maybe it was dropped or something before you put it in. Another first for me.
bumbaiulearn
11
Mar 28, 2006 12:49 AM
Touge Tuning
Jun 27, 2005 06:42 AM
boosted lude
Oct 10, 2004 12:23 PM
1dumbscreenname
Jul 17, 2003 01:15 PM
krazn
12
Nov 22, 2002 08:36 PM
