Spawne's supercharged B20, sponsored by DDTECH
Old Dec 15, 2012 | 04:12 PM
  #201
Spawne32's Avatar
Default Re: Spawne's supercharged B20, sponsored by DDTECH
Originally Posted by rich7777
I've been throwing countless money at my car for ages now. I hate giving up on anything
Honestly, giving up on this does make me feel as though i've failed miserably with this build. But at some point reason needs to take over and move me forward. Im not giving up on the motor itself, but I need to take a break from dumping loads of cash into this, ive literally dumped thousands into this car aimlessly since 2009.
Old Dec 15, 2012 | 04:36 PM
  #202
wantboost's Avatar
Who is Mr Robot?
Can you aimlessly send some my way lol? I need to finish my car too :p
Old Dec 15, 2012 | 04:38 PM
  #203
Spawne32's Avatar
lol its being sent aimlessly back to my savings account :x
Old Dec 15, 2012 | 04:41 PM
  #204
wantboost's Avatar
Who is Mr Robot?
But my love you long time, 10 dorrah
Old Dec 15, 2012 | 04:50 PM
  #205
Spawne32's Avatar
my soul is not for sale miss
Old Dec 15, 2012 | 04:56 PM
  #206
wantboost's Avatar
Who is Mr Robot?
Damn
Old Dec 15, 2012 | 05:00 PM
  #207
EsotericImage's Avatar
Retired Moderator
So are you going the same route as me? Hi comp B20 non vtec?
Old Dec 15, 2012 | 08:00 PM
  #208
Spawne32's Avatar
already was a high comp b20 non vtec, it just had a blower on it already lol
Old Dec 16, 2012 | 02:12 AM
  #209
rich7777's Avatar
I know what you're saying. Sometimes it does get frustrating and sickly when you've spent hours trying to get it right and something ***** up. It just kills me even more to know I've quit after getting so close though.
Good luck with plan b anyway. I hope it works out for you this time around.
Old Dec 16, 2012 | 12:32 PM
  #210
Spawne32's Avatar
I'm a little proud of this, these are my 402T cams with rotella T6 motor oil as the lubricant of choice after 1000 miles of non stop drag racing.
Old Dec 20, 2012 | 05:32 PM
  #211
Spawne32's Avatar
back onto the stand for brain surgery
Old Dec 20, 2012 | 05:40 PM
  #212
wantboost's Avatar
Who is Mr Robot?
Those cams look better than new lol
Old Dec 20, 2012 | 05:46 PM
  #213
Spawne32's Avatar
im curious to see what my bearings look like now lol
Old Dec 21, 2012 | 01:57 PM
  #214
Spawne32's Avatar
talk about f'ed in the a, all this time i was expecting to see issues with rings, and i pop out #1 (bearings looked brand new btw, thank god for something at least) and find ****** horrific skirt wear on the intake side. As far as I can tell something is wrong with the bore, must be out of round or something. Only thing I can assume is that this happened at the machine shop, i have uneven skirt wear across all 4 cylinders, #4 which appears to have barely anything, and barely anything on the exhaust side. Only a very fine line on the lower part of the cylinder.
Old Dec 21, 2012 | 02:05 PM
  #215
rich7777's Avatar
Unless the rods were slightly bent ?
Old Dec 21, 2012 | 02:07 PM
  #216
Spawne32's Avatar
crower H beams? you really think they could be bent?
Old Dec 21, 2012 | 02:15 PM
  #217
Spawne32's Avatar
Old Dec 21, 2012 | 04:34 PM
  #218
Muckman's Avatar
Moderator in Chief
Is it just the two pistons? The one doesnt look bad at all. At worse maybe replace the bad piston. I dont know if you could reuse if you moly coated the skirts, or if it would even be cost effective vs buying a single piston.
Old Dec 21, 2012 | 04:49 PM
  #219
Spawne32's Avatar
#1 is the worst, and its proggressive all the way to #4 which has basically no wear, dont know why
Old Dec 21, 2012 | 04:57 PM
  #220
94lsvturbo's Avatar
I havent read all this thread but i am curious, How much PTW clearance?
Old Dec 21, 2012 | 05:16 PM
  #221
Spawne32's Avatar
.0040
Old Dec 21, 2012 | 05:39 PM
  #222
wantboost's Avatar
Who is Mr Robot?
Definitely shouldn't have that issue at .004
Unless the machine shop fucked it up and the bore tapers, out of round, etc... unless you had uneven fuel delivery causing super high egts, causing the pistons to over expand
Old Dec 21, 2012 | 06:06 PM
  #223
Spawne32's Avatar
its all kinda contradictory to what im seeing, if that was the case, it would be hottest on #3 would it not? as #1 which is the worst is right in front of the water pump?
Old Dec 21, 2012 | 06:15 PM
  #224
h2.4's Avatar
What was your pin to small end clearance?
Old Dec 21, 2012 | 06:20 PM
  #225
Spawne32's Avatar
not an issue here
