spark plug gap
Old Mar 28, 2004 | 09:54 AM
LAKER HATER's Avatar
Default spark plug gap
what do you set your spark plug gaps at for your ls turbos with stock ignition?
Old Mar 28, 2004 | 09:56 AM
FOrSfEd's Avatar
Default Re: spark plug gap (lsturbo707)
.30 is a pretty good gap.
Old Mar 28, 2004 | 10:05 AM
b16ahybrid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsturbo707 &raquo;</TD></TR><TR><TD CLASS="quote">what do you set your spark plug gaps at for your ls turbos with stock ignition?</TD></TR></TABLE>
Depends on how much boost your runing.
6-10psi .034 is fine.....20+psi your going to want to run about .028
My understaning is that you want to run as much gap as you can without the boost blowing the spark out.
Old Mar 28, 2004 | 10:26 AM
Big Red 211's Avatar
Default Re: spark plug gap (b16ahybrid)
.028-.032 is good for almost any car.
Old Mar 29, 2004 | 07:39 AM
how much timing do you retard when using these gaps?
Old Mar 29, 2004 | 07:40 AM
b16ahybrid's Avatar
Default Re: (lsturbo707)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsturbo707 &raquo;</TD></TR><TR><TD CLASS="quote">how much timing do you retard when using these gaps?</TD></TR></TABLE>
How much boost you runing?
Gap doesn't determin retard, boost determins retard.
Old Mar 29, 2004 | 03:06 PM
Default Re: (b16ahybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16ahybrid &raquo;</TD></TR><TR><TD CLASS="quote">
Gap doesn't determin retard, boost determins retard.</TD></TR></TABLE>
7psi
Old Mar 29, 2004 | 04:04 PM
b16ahybrid's Avatar
You should be fine with stock timing, but you could retard it about 2 degree just to be safe.
high_revs
Oct 30, 2005 01:01 PM
booscivic
Jan 20, 2004 10:27 AM
reditr
Nov 12, 2003 12:58 PM
Chiovnidca
Aug 22, 2003 02:14 PM
swissturbo
Jun 14, 2002 11:33 PM
