Question BCP R 7E 11
Old Nov 12, 2003 | 11:16 AM
reditr's Avatar
Default Question BCP R 7E 11
Hi guys i have a drag 3 turbo kit and the seller has given me these plugs. I live in a small country in europe MALTA. I was talking about these plugs on my motor and every body told me that they are far way too hot, as i am only runing a set up of 8 psi of boost. Can somebody tell me if these are the wright plugs for me ? And how much can i boost up with these sort of plugs?, without risking out to melt down one of them?
Thanks in advance.
Old Nov 12, 2003 | 11:18 AM
b18bturbo's Avatar
Default Re: Question BCP R 7E 11 (reditr)
that is the correct plug.. bcpr7es11
it 2 steps colder than a stock plug
Old Nov 12, 2003 | 11:22 AM
ladysman's Avatar
Default Re: Question BCP R 7E 11 (b18bturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bturbo &raquo;</TD></TR><TR><TD CLASS="quote">that is the correct plug.. bcpr7es11
it 2 steps colder than a stock plug</TD></TR></TABLE>
Actually 1 step colder if its a DOHC.
They will be fine.
Johnyquest's Avatar
Yeah they are fine. If you go much colder, you risk sacraficing idle quality / plug fouling.
Old Nov 12, 2003 | 11:29 AM
swlabhot's Avatar
Default Re: Question BCP R 7E 11 (ladysman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ladysman &raquo;</TD></TR><TR><TD CLASS="quote">
They will be fine.</TD></TR></TABLE>
Actually its a DOHC B18C6.....Stock plug heat range for this motor is 7 so BCPR7E is the same heat range as stock?? Correct me if I'm wrong...
I used to use 1 step colder GReddy Iridiums but just switched over to these NGKs and seems to be going strong..
Old Nov 12, 2003 | 12:58 PM
reditr's Avatar
Default Re: Question BCP R 7E 11 (swlabhot)
That is correct my car comes with pfr 7 e 11. So what do you think shall i keep using these plugs? and how much boost can i apply on them?
fyre
Nov 16, 2006 05:52 AM
sethicusm
May 15, 2005 03:15 PM
Trailz-EX
Jan 23, 2005 01:33 PM
-iLLuZioN-B18C1
Oct 16, 2004 02:13 AM
vtec.dc2
May 9, 2004 09:41 PM
