spark plug gap
Old Jun 14, 2002 | 10:10 PM
swissturbo's Avatar
Default spark plug gap
My car does backfire about every 10th run @ WOT. Is it possible that the gap
from the spark plugs is too much?
swissturbo
Old Jun 14, 2002 | 10:12 PM
inspyral's Avatar
Default Re: spark plug gap (swissturbo)
What's your setup and plug gap?
Old Jun 14, 2002 | 10:29 PM
swissturbo's Avatar
Default Re: spark plug gap (inspyral)
gap is about 0.85 mm.
drag3 ,stock internals, compression 8.5-1(with gasket),msd 6a,5th injector from porsche turbo with the MF2 controlled,t3/t4.im bosting 12 psi.
the curious is that it only every 10 th fullboost run happend.
swissturbo
Old Jun 14, 2002 | 11:24 PM
inspyral's Avatar
you can try a .030" gap, which is between .75mm and .8mm, see if that helps
Old Jun 14, 2002 | 11:30 PM
swissturbo's Avatar
o.k thanx i will try this
but why is a smaller gap better for ignition?
do you guys all lower the original gap of the plug ?
swissturbo
Old Jun 14, 2002 | 11:33 PM
inspyral's Avatar
Smaller-than-stock gap is better for boost, since larger gaps may tend to blow out(the boost pressure extinguishes the spark before it ignites the mixture) under boost.
RubenPrelude
Jun 9, 2007 07:13 AM
i dunno
Honda S2000
Oct 13, 2006 01:02 PM
slowteg550
Jul 5, 2006 03:04 PM
booscivic
Jan 20, 2004 10:27 AM
intekragsr
Apr 21, 2003 06:03 PM
