someting wong! b18b ls-t not boosting at spring rate psi
so it's basically a ls-turbo with a .50 trim godspeed turbo, 2.5 piping, tial wastegate, greddy
type s bov, 440cc injectors, chrome. Anywho, so I got it tuned once at 6 psi with the tial
wastegate I bought used. so after a bigger fuel pump, and new charge pipes, i decided
to push atleast 10 lbs of boost so I ordered my wastegate 10 lb wastegate spring.
installed it. did test runs and it's only boosting at around 7-8 psi. so I don't know what's going on. If I hook up my boost controller, it will boost up to 10psi. but i want a consistent
and safe pressure thats why i went and bought the 10lb wastegate spring. any ideas?
Re: someting wong! b18b ls-t not boosting at spring rate psi
Where do you have your wastegate hooked up to? If you have a shitty intercooler, and your wastegate reference is the intake manifold, that's your pressure drop across the intercooler. Pretty high for a low boost setup
on it.
My bad, I got it backwards. If the wastegate is hooked up to the intake, the actual pressure output by the turbo will be above spring pressure, but the engine will see spring pressure at the intake manifold. If you have it hooked up to the turbo or pre-intercooler, boost at the intake manifold will be lower than spring pressure due to pressure drop across the intercooler
Check for boost leaks
DO IT ON ALL FOURS
Not just that but did you buy a TiAL wastegate springwith the correct color for your unknown model TiAL wastegate? Or was it some random cheap copy spring from an eBay seller?
Sounds like a cheapo wg and spring combo. Just run the MBC and get the 10 pounds that way or buy real stuff and these issues wont occur
it's a tial wastegate. and I bought the 10 psi spring off of a local reputable store called
atp turbo. it's genuine 35-38mm yellow wastegate spring.
It's wU to the sOLdiEr!
let me see if i read this right
your tuned for 6lbs but now you want to do 10lbs? i assume you made the proper fuel adjustments
GSRswapandslow.
06-17-2004 01:49 PM
boredracer408
11-25-2003 12:47 AM
t616
06-26-2003 08:52 AM
