SOMEONE HELP ME!
Old Mar 11, 2011 | 03:27 PM
roudiiboii's Avatar
Default SOMEONE HELP ME!
OK SO I HAVE A NEWLY REBUILT B18C5 AT FIRST I WAS HAVING PROBLEMS BECAUSE THERE WAS NO SPARK. NOW I HAVE THE SPARK BUT NOTHING!!! THE TIMING IS SET I JUST CANT FIND THE SOLUTION CAN ANYBODY HELP ME WITH THIS?!?!?!
Old Mar 11, 2011 | 03:37 PM
Destructive-'s Avatar
Default Re: SOMEONE HELP ME!
WHY ARE YOU SCREAMING!!?!?!?! PLEASE STOP TYPING LIKE THIS IT MAKES IT HARD TO READ YOU SHOULD TRY TAKING OFF YOUR CAPS LOCK AND THEN MAYBE PEOPLE WOULD TAKE YOUR POST SERIOUSLY AND TAKE THEIR TIME TO HELP YOU DIAGNOSE YOUR PROBLEM!!!! IT CAN BE ALOT OF THINGS LIKE MAYBE YOUR IGNITION TIMING!!! CHECK THE BASICIS!! MAKE SURE YOU HAVE FUEL AS WELL BECAUSE YOU ALSO NEED FUEL APART FROM SPARK TO START AN ENGINE!!!!!!!
Old Mar 11, 2011 | 03:51 PM
11psiGSR's Avatar
Please read this thoroughly before posting. Especially points #2 and #3.
https://honda-tech.com/forums/forced-induction-16/new-fi-forum-rules-lets-turn-place-back-around-2164678/
Thank you from the rest of the world.
Old Mar 11, 2011 | 06:43 PM
roudiiboii's Avatar
sorry about the caps lock
Old Mar 11, 2011 | 11:06 PM
SIXTY-1HATCH's Avatar
Just go over all the basics first!! You said you now have spark, so thats out of the way. Now you need to check for fuel and make sure all that getting thru. Double check your timing, the slightest bit off will cause issues, meaning a tooth or so will cause issues. Also, if your head is new or what not, double check the valve adjustment. I remember my first build I double checked EVERYTHING TWICE and couldnt' find anything. Wound up being the valve adjust, and she started right up after that. Just go over the basics first, and make sure there are no CEL's on, and if so check them and fix them!!
scotty.b16a1
Dec 31, 2012 01:54 PM
4drint3gr4
Apr 9, 2010 11:23 PM
vtecsi00
10
Feb 25, 2008 06:44 PM
95civickid
11
Apr 5, 2005 05:52 PM
chirp2hrd
Jun 8, 2003 03:15 PM
