SOHC d15b7 turbo?
Old Apr 26, 2004 | 07:30 PM
Serdar's Avatar
Default SOHC d15b7 turbo?
I want to boost a stock sohc d15b7 motor with Z6 tranny. I want to use a small Ko3 Vw stock turbo (1.8T) with a Hf manifold and adapter plate, it will be not be intercooled, 2 1/4inch mandrel bent piping w/hks bov and ACT clutch. My question is what is a good guess to how much Hp is attainable at 7psi with this Simple set-up? This will be my first project so please help me out.
Old Apr 26, 2004 | 08:12 PM
RyanEJ8's Avatar
Default Re: SOHC d15b7 turbo? (Serdar)
I would recommend getting an intercooler to boost 7 psi.
BTW, I work at Progressive in Riverview.
Old May 2, 2004 | 10:54 AM
thrty8street's Avatar
up, i want to know too.
Old May 2, 2004 | 11:06 AM
Sinner's Avatar
Lets use examples
a d16z6 at 10 psi hits around 200 hp.
a d15b7 is around 100hp, lets say its ups 80 to the ground. well 7psi couuld be around 50-70 hp depending on your setup. This is an idea of where you might stand.
Nick
Old May 2, 2004 | 11:38 AM
Slammd Sol's Avatar
i made 141 hp and 140 tq on 5psi with my old d15b7
Old May 2, 2004 | 01:58 PM
Johnyquest's Avatar
Default Re: (Slammd Sol)
My buddy's greddy hatch d15b7 moves real good. It's about even with my d16z6 coupe....
You'll have fun w/ it.
Old May 2, 2004 | 05:09 PM
Default Re: (Johnyquest)
you also have to consider that its a 1.5 liter not a 1.6 and it also doesnt have vtec like the z6 does
Old May 2, 2004 | 07:35 PM
Acrappyhatch's Avatar
im about to turbo my d15. but using a t25 turbo. how are the oil lines ran on these set-ups?
Old May 3, 2004 | 08:02 PM
lohatch's Avatar
Default Re: (AcrappyHatch)
you use the hole in the back of the block where the oil pressure sending unit is located, and then using -4an or -3an stainless steel lines run it to the turbo. hit up flamencoT here on HT. he can hook you right up
Old May 3, 2004 | 08:58 PM
dohcnotec's Avatar
Default Re: (lohatch)
https://honda-tech.com/zerothread?id=853131
Old May 4, 2004 | 01:22 PM
Default Re: (dohcnotec)
thats tight, that what i want to do!
95phoenEX
May 2, 2006 01:30 PM
MugenT
23
May 8, 2005 05:03 AM
New Dimensions
Mar 28, 2005 09:54 AM
blkeg
Jan 17, 2004 03:33 PM
yusoslo
23
Jan 6, 2003 07:40 PM
