Slevee Question
Old Oct 22, 2007 | 06:17 PM
Da9_Rider's Avatar
Default Slevee Question
Here is my question on sleving a block ... i have a cracked sleeve (stock block) on my b18c i was looking toward sleeving it but not sure if i could do that with this block, i know they cut out the old one and machine the new ones on the block ... is it posible or got to get a new block ???
I was looking at the golden eagle and darton sleeves but don't know wich one i should get maybe some advice from guys who have done it or with more experience.
im planing on boostin aroude 400whp with sleeves and piston rods ...
Thanks in advance
Old Oct 22, 2007 | 06:54 PM
integraRS-T's Avatar
Default Re: Slevee Question (Da9_Rider)
alot of peps use darton but im sure both are good and yes they can replace ur old cracked sleeve
Old Oct 22, 2007 | 07:39 PM
ninesecrx's Avatar
Default Re: Slevee Question (integraRS-T)
It depends on how far the crack goes down on the block, but most of the time it can still be used.
Old Oct 23, 2007 | 09:18 AM
Da9_Rider's Avatar
till where is the maximum maybe i can mesure it so i can be sure before sending it out ??
Old Oct 23, 2007 | 09:43 AM
ninesecrx's Avatar
Default Re: (Da9_Rider)
I know with Benson's stuff, 4-6 inches is no problem.
Old Oct 23, 2007 | 11:45 AM
Darton's Avatar
Default Re: (ninesecrx)
It will also depend on if the stock liner is cracked or if the crack goes all the way through the aluminum.
Old Oct 23, 2007 | 11:52 AM
crowder13's Avatar
recommend benson, i have ge sleeves but benson fixed my buddys block and i thought it was trashed
Old Oct 23, 2007 | 12:03 PM
CerealKiller's Avatar
I personally use Golden Eagle, You should try to get a pic of the block and email it over to them, this way you won't waste mula. Have had no problems with re sleeved block. boosting 35.lbs
sales@goldeneaglemfg.com / or you can pm them on H-T.
Old Oct 23, 2007 | 01:22 PM
rip94delsol's Avatar
Default Re: Slevee Question (inlineaddict)
alright before this gets into a pissing match.
Op, send pics of your block to golden eagle and Laskey Racing. See what they say and go from there.
Everyone knows the whole sleeve deal so lets just help out the op. I can already forsee this thread going downhill
If you have a question on wether what company to send you block to try searching benson vs golden eagle or sleeved blocks.. There is plenty of info on here and there is no need to waste bandwidth on more arguements. Either way they are both good companies its just ppl's opinions and history with blocks.
Old Oct 23, 2007 | 01:46 PM
Default Re: Slevee Question (rip94delsol)
TRUE
Old Oct 23, 2007 | 02:00 PM
Golden Eagle's Avatar
send pics to robert@goldeneaglemfg.com ill let you know if we can fix it or not
98_Milano_Teg
Jan 30, 2012 03:35 AM
1G_DX_to_2G_Si
Oct 26, 2005 05:32 PM
someday
Jul 1, 2005 09:58 AM
VNTEC
Dec 22, 2003 12:46 PM
