LS block VS gsr block
Old Jan 27, 2005 | 01:51 PM
EK FLY's Avatar
Default LS block VS gsr block
I did a search for like an hour and I couldnt find **** about it ,I resently blown piston 3 and it had a little scratches on the slevees u couldnt note the scratches if look at it but if u went allover it whit ur hand u could feel it is just a like a someone came with sand paper and star sand it that how the scratche looks but well i decide to change pistons only so I was woundering what is the diference betwen the ls block and the gsr is there any posibility i can change all the gsr internals to an ls block and the head and **** and still being the normal gsr ?
Old Jan 27, 2005 | 02:48 PM
EK FLY's Avatar
Default Re: LS block VS gsr block (racing_beat)
so no one know what's the diferent betwen the ls blck and the gsr block ummmmmmmmmm........................
Old Jan 27, 2005 | 03:11 PM
GDM Z28's Avatar
gsr block uses a girdle and has oil squiters, you can use ur gsr crank, rods, and pistons in a ls block but u wont have a girdle or oil squirters. just hone the gsr block n see if it fixes it or get .020 over pistons n go 81.5mm
Old Jan 27, 2005 | 03:14 PM
EK FLY's Avatar
Default Re: LS block VS gsr block (civicflnum1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicflnum1 &raquo;</TD></TR><TR><TD CLASS="quote">gsr block uses a girdle and has oil squiters, you can use ur gsr crank, rods, and pistons in a ls block but u wont have a girdle or oil squirters. just hone the gsr block n see if it fixes it or get .020 over pistons n go 81.5mm </TD></TR></TABLE>
but then I need oversized pistons isnt it ?
Old Jan 27, 2005 | 04:40 PM
cnydc2's Avatar
If you bore the cylinder walls then you will need oversized pistons.
Old Jan 27, 2005 | 04:51 PM
GDM Z28's Avatar
if you just hone it you shouldnt if u bore u will...just buy oversized pistons if ur gonna buy ne ones....
Old Jan 27, 2005 | 05:03 PM
PrettyLude's Avatar
yes
Old Jan 27, 2005 | 05:07 PM
EK FLY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicflnum1 &raquo;</TD></TR><TR><TD CLASS="quote">if you just hone it you shouldnt if u bore u will...just buy oversized pistons if ur gonna buy ne ones....</TD></TR></TABLE>
so whats the big diference betwen hone and bore I dont understand that sorry i'am a noob on this
Old Jan 27, 2005 | 05:17 PM
GDM Z28's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racing_beat &raquo;</TD></TR><TR><TD CLASS="quote">
so whats the big diference betwen hone and bore I dont understand that sorry i'am a noob on this </TD></TR></TABLE>
boreing is making it bigger and making sure the cyl is perfectly round all the way down and fresh (best thing to do)
hone just cleans it up alittle...if u said the scratches arnt deep at all a honda might be enough.
Modified by civicflnum1 at 2:32 AM 1/28/2005
Old Jan 27, 2005 | 05:27 PM
SkRiBLaH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicflnum1 &raquo;</TD></TR><TR><TD CLASS="quote">...
honda just cleans it up alittle...if u said the scratches arnt deep at all a honda might be enough.</TD></TR></TABLE>
i think by HONDA you mean HONE
Old Jan 27, 2005 | 05:31 PM
GDM Z28's Avatar
Default Re: LS block VS gsr block (SkRiBLaH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkRiBLaH &raquo;</TD></TR><TR><TD CLASS="quote">
i think by HONDA you mean HONE</TD></TR></TABLE>
lol yeah my b...edited
Old Jan 27, 2005 | 05:38 PM
NJIN BUILDR's Avatar
Didn't know honda was a machining prosses..lol
Boring a block is a cutting process used to enlarge the cylinder size.It is a ruffing process usually accurate to about a .001".This is followed by honing the bores.This is a grinding operation that is very accurate that leaves the cylinders very round.Honing also leaves a crosshatch pattern that helps in ring break in.This is a very accurate operation that is repeatable to .0001".
You can hone a small amount or material out of the bores without having to go to the next piston oversize.
Glenn
Old Jan 27, 2005 | 07:54 PM
EK FLY's Avatar
Default Re: LS block VS gsr block (NJIN BUILDR)
I'LL DO THAT i was thinking on runing like that with the scratches and everithing but now I know what to do , and thanks for those who reply
Old Jan 27, 2005 | 10:57 PM
GDM Z28's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racing_beat &raquo;</TD></TR><TR><TD CLASS="quote">I'LL DO THAT i was thinking on runing like that with the scratches and everithing but now I know what to do , and thanks for those who reply </TD></TR></TABLE>
dont run with scratches. take the block to a machine shop and ask them if a hone will take car of it.
vpower101
Jan 21, 2008 10:47 AM
ABCVTEC
14
Nov 15, 2006 08:59 AM
russianswty
Oct 17, 2006 03:09 PM
faSHOwidIT
Aug 2, 2006 04:40 AM
