the use of O-rings with stock headgasket??
can it be done? should it be done when you want a good tight seal?
where would you get O rings seals for 84.5mm cylinder bores?
thanks.
thanks.
Re: the use of O-rings with stock headgasket?? (non-VTEC)
yea... u can use them with a stock headgasket... u make them urself... putting wire into the groove of the sleeve
Im assuming that you already have the block sleeved and your asking where to get he copper wire, right? If it is jsut go to a speed shop that deals with older musclecars and they will know exactly what you are talking about. They will probably have it in stock.
Re: the use of O-rings with stock headgasket?? (boosted3g)
accualy the block is not sleeved. i just wante to get a really tight seal using those O rings on the stock block/sleeves
i'll check around a few shops and see what they say.
thanks
thanks
U need to put a groove in the block or the head to use o-rings. The groove holds the o-ring in place
spooledex
02-17-2004 09:44 AM
