sleeve question?
Old May 18, 2004 | 07:10 AM
loserface's Avatar
Default sleeve question?
Gonna boost my car but didn't want to put out money to get sleeves.. How many psi or HP is safe to push? getting bigger injectors, hondata, also might be thinking of getting forge piston 9:1 and eagle rods. Thinking about 300 whp or 12 psi?
Old May 18, 2004 | 07:12 AM
ABK's Avatar
ABK
Default Re: sleeve question? (loserface)
what motor you got?
Old May 18, 2004 | 07:34 AM
SpoolinEK9's Avatar
From: Seattle/Ligonier, WA/PA, United States of Honda
Default Re: sleeve question? (ABK)
spend the money on sleeves so u can boost like 20+psi
Old May 18, 2004 | 07:50 AM
CivicEKCP's Avatar
Default Re: sleeve question? (SpoolinEK9)
I would spend the money on sleeves if you plan to do 12 psi or higher....I beleive that honda motors aren't safe after 10psi....I think i read that somewhere....do a search for sleeving this will help you to determine your answers
Old May 18, 2004 | 07:57 AM
loserface's Avatar
Default Re: sleeve question? (CivicEKCP)
i did a search but none of them answer the question on how much stock sleeves can take. I am getting b18c1 obd 1.. i was going to switch the gsr head for a b16 head and get 9:1 pistion but with the swap of head the compression should be 8.8:1 or something like that.. so you say 10 psi huh? hmm that is not enough for me. i guess i have to get some sleeves then.. thanks for the help H-T!
Old May 18, 2004 | 08:26 AM
ATS*Mark's Avatar
OG triple OG
its all in the tuning , ive seen stock d series put out almost 400whp on stock sleeves
Old May 19, 2004 | 06:38 AM
loserface's Avatar
Default Re: sleeve question? (Hella_JDM)
400 whp but how long did that motor last? 1 run maybe 2? haha
Old May 19, 2004 | 07:34 AM
ATS*Mark's Avatar
OG triple OG
who knows.....
like i said its all in the tuning . if you can control that burn in the chambers and keep it off the walls , then the pressure should be fine inside.
91grape
Sep 8, 2012 02:19 PM
Topdawgg
Aug 1, 2006 11:05 AM
Topdawgg
Feb 17, 2006 10:20 PM
1gen crxer
Apr 28, 2004 04:37 PM
Happyman
Jan 25, 2003 02:53 PM
