LS Vtec Vortech?
Old Feb 19, 2004 | 08:57 AM
TheYellowDart's Avatar
Default LS Vtec Vortech?
I have a 00 si with the vortech after cooled system on it. Then i messed up my bottom end and found a good deal on a built LS motor. i want to take the bottom end off the LS and but my head on it. Does anyone know of someone doing this? How much boost will i be able to run?
Thanks Tony
Old Feb 19, 2004 | 11:55 AM
dfoxengr's Avatar
Default Re: LS Vtec Vortech? (TheYellowDart)
whats the bottom cosist of. you need to give details. but even so stock bottoms can hold enough pressure.
Old Feb 19, 2004 | 12:04 PM
BROOD's Avatar
LSVtec nope never heard of it......
You will probably get ding'ed with lots of search suggestions. At least that is what I was gonna say, but how can I be rude to another IL H-T'er?
Yes it can be done. But your success is dependent on how well you perform the swap.
Depending on how built the LS bottom end is........
At least, you will need to swap the LS rod bolts out for APR rod bolts. The oem LS rod bolts are the weak link in the rotating assembly. I also suggest installing a Vtec water pump (B16A, B18C1, B18C5) and timing belt (B18C1, B18C5) to retain the cooling range when running the LS bottom end at higher than designed rpms.
You will also need to either buy LSVtec dowels or have your cyl head modified to move the dowels. I strongly suggest the Full Race dowels...it is just too easy.
You will also need to supply oil to the Vtec cylinder head seeming that there are no internal oil passages in the LS block. I suggest the GEM filter adapter. Not to mention you will have to tap and plug the original cyl head oil port with a steel allen plug.
There is alot of other details but at least this will get you on the right track....try the search button too. There are aolt of good informative posts about LSVT engines. Good luck
Modified by BROOD at 1:17 PM 2/19/2004
Old Feb 19, 2004 | 12:16 PM
Default Re: LS Vtec Vortech? (BROOD)
This is the bottom end i will proly get Darton single sleeves - closed deck design 81mm bore
SRP pistons
Eagle Rods
ACL bearings
ARP head studs
LS crank
Do you think the end product will be worth it? will i lose boost
Old Feb 19, 2004 | 12:18 PM
dfoxengr's Avatar
you cant lose boost, lol.
Old Feb 19, 2004 | 12:20 PM
BROOD's Avatar
I feel that the displacement increase from your B16A bottom end will make the change well worth it. Especially since it sounds like you are swaping a stock B16A shortblock for a built shortblock. Besides I'm a LSVT junkie
You will have to retune to compinsate for the increase in displacement...rather large change in engine configuration.
You won't be able to IM (trial user) but I can shoot you an email and help with any questions.
moyospeed
May 13, 2010 01:03 PM
175Shot4Door
Mar 6, 2009 11:58 AM
lickety_britches
Nov 15, 2008 06:51 PM
crxsi8
Dec 9, 2005 04:08 PM
92eg6lsvtec
Jul 22, 2005 12:40 PM
