Boost wont gain no more??
hey im running d16y7 on 450's safc2 rfl bov, fmic wrx turbo setup... i had wastgate hook up to vacuum just running the 5psi give or take.. i put on boost controller and wont go pass the 5psi i tried taking off wastegate to see if it even goes pass 5 psi at full throttle but doesnt.... does this mean wastegate is bad?
Re: Boost wont gain no more?? (EK k kay)
dont even bother turn n the boost up if ur gonna run a SAFC. run crome or uberdata and then safely turn up the boost.
also check out ur boost controller and vacuum lines
