HONDATA or UBERDATA
Old Jan 4, 2008 | 07:36 PM
CaymanNational's Avatar
Default HONDATA or UBERDATA
I have a s300 hondata in my turboR. but my friend wants to use his uberdata on my car, cause he doesnt know how to use the hondata program, and i have no idea how to use it either yet. THere is no one here in the islands that knows how to really tune it. What should i do? should i try and tune it with the hondata or uberdata?
Old Jan 4, 2008 | 09:06 PM
neo_'s Avatar
Default Re: HONDATA or UBERDATA (CaymanNational)
Uberdata is outdated, not as solid, and just a bad choice. You will definetly be downgrading if you switch to Ubderdata - which is chip based from a real time programmable system - Hondata S300.
But on the other hand, if your tuner is not familiar with Hondata S300 the tune will never be as good as an experienced Ubderdata tuner.
Old Jan 4, 2008 | 09:30 PM
Doostur's Avatar
I agree. Since your from teh Caylan islands I'm sure you dont have a wide variety of choices. I would go with whatever the best tuner uses
Old Jan 4, 2008 | 09:45 PM
tech7427's Avatar
Default Re: HONDATA or UBERDATA (neo_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neo_ &raquo;</TD></TR><TR><TD CLASS="quote">Uberdata is outdated, not as solid, and just a bad choice. You will definetly be downgrading if you switch to Ubderdata - which is chip based from a real time programmable system - Hondata S300.
But on the other hand, if your tuner is not familiar with Hondata S300 the tune will never be as good as an experienced Ubderdata tuner. </TD></TR></TABLE>Bad Choice ? what the hell is wrong with uberdata ? good lord...
Old Jan 4, 2008 | 09:59 PM
neo_'s Avatar
Default Re: HONDATA or UBERDATA (tech7427)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tech7427 &raquo;</TD></TR><TR><TD CLASS="quote">Bad Choice ? what the hell is wrong with uberdata ? good lord...</TD></TR></TABLE>
Comparing Uberdata to the rest is as follows.
Hondata
Neptune
eCtune
Crome
Zdyne
All have more FEATURES, more SOLID, fluid SOFTWARE, better SUPPORT then Uberdata. I said bad choice because all of the above ECU sytems perform a better job then Uberdata, and when such stands, using Uberdata is a bad choice. Yes Ubderdata is a great choice back in the day, there was nothing wrong with it, but we have have gone so much father with programmable ECUs then Uberdata currently stands. Just the point that you questioned the fact of a EEPROM based system to RTP is naive. Yes, not everyone needs the function but it is the principal in this argument which I am referring to. Lets not make this a fan boy debate, stick to the facts. Denying technological advances which makes tuning more easy and sold is shrewd. When there are better choices out there, and you stick to something behind the times - that is fine. Just don't try to blindly push your beliefs onto others. State facts which can sway a people's opinion and not raw opinions which serve no use in a recommendation.
Old Jan 5, 2008 | 02:05 AM
mtber's Avatar
I would recommend Hondata over Ubderdata.
Old Jan 5, 2008 | 07:19 AM
pasaunde's Avatar
Default Re: (Doostur)
X3 Tuners choice
Old Jan 5, 2008 | 07:33 AM
Thanks everyone for your insight. HONDATA it is then. I'll just have to play around with it a little to learn it better. I get a bit of it, and have a friend or two that knows a little more about it than me. I'll let you know my times at the track. Should be pushing 25-30 psi. sux we only have a 1/8 mile track here. Give it another year and i think we should have the 1/4 done.
ALL the best for the NEW YEAR!
1995Civiccx
Jul 19, 2007 01:34 AM
L_K
Oct 16, 2006 06:49 PM
BB2_SI
Jun 21, 2006 12:18 AM
ForceFedIntegra
Dec 20, 2005 08:57 PM
ONISHIMA
Jul 29, 2005 07:40 PM
