Second clutch failed need some help..
Who is Mr Robot?
Not a problem.
Realistically you could use the CC stage 3 and be fine. I don't think your current setup could break the 350lbft mark. However depending on your driving style and how you use the car the higher torque capacity stage 4 could probably withstand more abuse due to the friction material. IIRC per competition all of the b series clutches use the same pressure plate, it's only the driven disc friction material that changes. At least that's how it used to be.
Also remember like s stated above that the more aggressive the clutch the lower the lifespan tends to be.
From: "Try stealing my car I drive a bait car" Long Beach CA
Not a problem.
blkonblkcrime
May 29, 2007 10:05 PM
