Turbo Noob in Need of Help
Old Dec 12, 2007 | 08:27 PM
Sloshy's Avatar
Default Turbo Noob in Need of Help
So in a market for a turbo, and i want to know what's the difference between t3/t4 and t3/to4e?
I'm scared of ordering the wrong turbo and that it wont fit my manifold and downpipe..
so basically are t4 to4e t4b all the same, and will they fit my dp which is design the for t4
(I'm having trouble finding T4 or i just dont know where to look)
Old Dec 13, 2007 | 05:55 AM
Schister66's Avatar
Man U FTW
Default Re: Turbo Noob in Need of Help (Sloshy)
Most of the confusion stems from the fact that when people write online, they tend to shorten things that are unnecessary. Turbos are not denoted "T3/T4." A standard hybrid turbo is denoted "T3/T04x," but in order to save time, people cut the "0" out of the name.
<U>T3</U>
The T3 portion refers to the T3 turbine, or exhaust, housing which tells you the general turbine size; however, there is great variation within that T3 grouping. To have a better understanding of the turbine side, you may consider learning more about turbine wheels, trim, and aspect ratios (ar).
<U>T04x</U>
The T04x portion refers to the compressor side of the turbo. The T04 means that it is a T04 framed compressor. The letter following the "T04" is the compressor housing. The compressor housings you will see most often are the "B, E, and S" housings; however, there are several more. To give you an idea of the differences, here are a few pictures:
T04b (my gt3255b)
From left to right----T04E (60 trim) and T04S (60-1)
Old Dec 13, 2007 | 11:01 AM
SteamedRice's Avatar
Default Re: Turbo Noob in Need of Help (Schister66)
ummmm...... yeah....
Old Dec 13, 2007 | 11:53 AM
Schister66's Avatar
Man U FTW
Default Re: Turbo Noob in Need of Help (SteamedRice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SteamedRice &raquo;</TD></TR><TR><TD CLASS="quote">ummmm...... yeah.... </TD></TR></TABLE>
Old Dec 13, 2007 | 12:08 PM
morgan@synapse motorsport's Avatar
who made your manifold and downpipe? most t3/t4 turbos are interchanble and have the same external exhaust dimensions but not all. talk to the manifold and downpipe maker and see what turbos swap in.
what turbo was the downpipe made for?
Old Dec 13, 2007 | 05:13 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">
??</TD></TR></TABLE>
i was kinda confused by your explanation... is there a thread that explains this in detail?
Old Dec 13, 2007 | 07:21 PM
ls19integra95's Avatar
i know what your asking... i have a t3/t4 turbo, a t3/t04e turbo, and a t4 turbo... lol yes i have all three of them, ive been experimenting... the t3/t4 and the t3/t04e manifold and downpipe are interchangable BUT if you have just a T4... then it most likely wont work because on a T4 turbo where it bolts to the manifold is much larger and also for the downpipe, it clamps on instead of bolting on like the t3/t4 and t3/t04e...
Old Dec 14, 2007 | 11:04 PM
Sloshy's Avatar
Default Re: Turbo Noob in Need of Help (mike@synapse motorsport)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike@synapse motorsport &raquo;</TD></TR><TR><TD CLASS="quote">who made your manifold and downpipe? most t3/t4 turbos are interchanble and have the same external exhaust dimensions but not all. talk to the manifold and downpipe maker and see what turbos swap in.
what turbo was the downpipe made for?</TD></TR></TABLE>
Spoolin performance bought it brand new..
it's made for t3/t4 (to4*) turbo with 5 bolt ac friendly downpipe and dumptube
Old Dec 14, 2007 | 11:06 PM
Sloshy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">Most of the confusion stems from the fact that when people write online, they tend to shorten things that are unnecessary. Turbos are not denoted "T3/T4." A standard hybrid turbo is denoted "T3/T04x," but in order to save time, people cut the "0" out of the name.
g]</TD></TR></TABLE>
wow thanks man that helped a lot, i was scared of ordering the wrong turbo and it wasn't going to fit my dp..
Old Dec 14, 2007 | 11:15 PM
Sloshy's Avatar
Default Re: Turbo Noob in Need of Help (ls19integra95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ls19integra95 &raquo;</TD></TR><TR><TD CLASS="quote">i know what your asking... i have a t3/t4 turbo, a t3/t04e turbo, and a t4 turbo... lol yes i have all three of them, ive been experimenting... the t3/t4 and the t3/t04e manifold and downpipe are interchangable BUT if you have just a T4... then it most likely wont work because on a T4 turbo where it bolts to the manifold is much larger and also for the downpipe, it clamps on instead of bolting on like the t3/t4 and t3/t04e...</TD></TR></TABLE>
yeah i figured that the the t3 portion is the part on the manifold..
but what i was trying to figure out was what the hell all this to4e, to4b, and to4s where i couldnt just find a t3/t4 it alway had letter behind it.. but know i get it they're all the same its just a different on the shape of the intake turbine deal (dont know what is called lol)
Old Dec 15, 2007 | 09:44 AM
Sloshy's Avatar
i like the t3/t04s and t3/t04b turbo how much do the generally go for new and where can i get one?
Old Dec 17, 2007 | 09:51 AM
Sloshy's Avatar
anyone else who wants to input info is welcome...
lol
Old Dec 17, 2007 | 02:13 PM
Schister66's Avatar
Man U FTW
-what's your budget?
-what's your setup?
-what are your power goals??
After we know that and the engine specs, we can help you out in finding a turbo for your needs. You said it was for a 5 bolt dp right??
Old Dec 17, 2007 | 02:26 PM
GraphiteAccord's Avatar
Default Re: (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">-what's your budget?
-what's your setup?
After we know that and the engine specs, we can help you out in finding a turbo for your needs. You said it was for a 5 bolt dp right??</TD></TR></TABLE>
You deserve a medal for being so patient.
Old Dec 17, 2007 | 02:31 PM
Schister66's Avatar
Man U FTW
Default Re: (GraphiteAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GraphiteAccord &raquo;</TD></TR><TR><TD CLASS="quote">You deserve a medal for being so patient.</TD></TR></TABLE>
Lol...i'm done with Finals and have all the patience in the world right now. I wont lie, i'd like a medal too
Old Dec 17, 2007 | 05:17 PM
Sloshy's Avatar
-what's your setup?
- 550 and maybe a little more if its really worth it for the turbo
- spoolin perfomance ac friendly log manifold, 2.5" 5 bolt dp, 38mm tial wastegate, 1.5"
open dt, 2.25" ic piping
ek hatch stock healthy gsr motor.. planing on getting tial bov, and a black ic (stealth)
- 250-300hp max (dont wanna blow it up, i think thats safe, is it?)
Old Dec 17, 2007 | 06:19 PM
Schister66's Avatar
Man U FTW
I would have gone w/ a larger downpipe personally, but if you're on a budget, then that's good enough for now. For your goals, it wont make a big difference anyway.
Your setup is almost identical to my first setup. I made 275/194 w/ a SPoolin log, 2.5" dp and a 60trim turbo. I would suggest a T3 Super60 for your setup. You may want to invest in an aftermarket map sensor because you might be looking around 11-12psi for your goals. That would be a pretty wicked street setup and the Super60 is pretty cheap too.
If you have any other questions, just PM me and i'll help you out
Old Dec 17, 2007 | 07:34 PM
Sloshy's Avatar
yeah i wanted to have a bigger downpipe but i was scared of running into clearance issues since im keepin a/c..
Where can i get t3 super 60 from and whats a good price for it?
BoOsTiN Dc2
Jun 9, 2004 11:24 PM
1.8T_EG
Oct 30, 2002 09:50 AM
Lei Siew Long
Feb 11, 2002 02:49 AM
