S-AFC 2 or smc???
Old Oct 24, 2003 | 05:31 AM
sCeRaXn's Avatar
Honda-Tech Double Platinum Member
Default S-AFC 2 or smc???
I need either an smc or an afc for a temporary fuel controller. I have a b18a in a crx thats turbo'd. Im running 7psi on stock injectors and an fmu right now. I just ordered some rc440's and im going to hook up my msd inline too...so i needsomething to lean it out a little. The smc500 is cheap and ive heard that its easier to use...but the new safc can display all the stuff its reading including boost which it couldnt do before. So i guess im asking which is better...the smc or the hack? Ive heard some bad stuff about the hack lately...but i dont know if its all true. So what do you guys think? And please dont tell me to useuberdata...i dont have time to do all that is involved in getting that to run right. I just want something that i can plug up...do a little tuning on the butt dyno and drive. Thanks
Sean
Old Oct 24, 2003 | 06:47 AM
sCeRaXn's Avatar
Default Re: S-AFC 2 or smc??? (sCeRaXn)
up up and away!!!
Sean
Old Oct 24, 2003 | 07:03 AM
GreddySi99's Avatar
safc is more adjustable.SMC is cheaper. you be the judge
Old Oct 24, 2003 | 07:04 AM
Johnyquest's Avatar
Default Re: S-AFC 2 or smc??? (intercooledJRSC)
either will work, and you don't need your inline fuel pump. stock pumps plenty @ stock fuel pressure.
Old Oct 24, 2003 | 07:06 AM
sCeRaXn's Avatar
Default Re: S-AFC 2 or smc??? (Johnyquest)
Are there any advantages/disadvantages to using either one? Like does one cause hesitation before boost or anything like that? THanks
Sean
Old Oct 24, 2003 | 07:12 AM
COOKIEPUSS's Avatar
I was researching this for a while myself. THe SMC is a nice inexpensive unit, unfortantly I have researched it, and even Emailed to get more info. I wanted to know about timing, and a few other things, and all I got back was it works great w/ an MSD. In other words I couldn't find any tech help on the SMC. I have heard people using it succesfully and with good times. I think the new AFC you would be able to get a lot more tech info on. I know this probally isn't helping you much, but when I searched that was all I was able to find. I decided and saving to go w/ Hondata, or AEM EMS. You could also look into uberdata.
Old Oct 24, 2003 | 07:15 AM
sCeRaXn's Avatar
Default Re: S-AFC 2 or smc??? (COOKIEPUSS)
This is just going to be temporary...im going to go hondata eventually. And once again...im not going to use uberdata. I dont have the time to get it running right. Keep the comments and opinions coming.
Sean
Old Oct 24, 2003 | 08:17 AM
slooogsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Johnyquest &raquo;</TD></TR><TR><TD CLASS="quote">either will work, and you don't need your inline fuel pump. stock pumps plenty @ stock fuel pressure.</TD></TR></TABLE>
so your saying its not necessary to install an aftermarket fuel pump when using 440 or 450's and the afc?
if i can just get away with bumping the fuel pressure up a bit that would be sweet......
Old Oct 24, 2003 | 08:20 AM
slooogsr's Avatar
man the safc2 is 300bucks......... if the differences are minimal i would just go with the smc..........
Old Oct 24, 2003 | 01:47 PM
drvfast's Avatar
Default Re: S-AFC 2 or smc??? (sloorex)
install a high pressure fuel pump for saftey. you can run the hack with your stock fuel pump. i recommed getting the walbro 255
Old Oct 24, 2003 | 03:26 PM
mos's Avatar
mos
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by intercooledJRSC &raquo;</TD></TR><TR><TD CLASS="quote">safc is more adjustable.SMC is cheaper. you be the judge</TD></TR></TABLE>
You must be talking about the old SMC. The new one is adjustable every 500rpm and has dual settings, you can switch from one to another at a preset PSI. It also has an adjustable max voltage to to the map input on the ECU. It might not be as good as using hondata or some of the other stuff out there, but I think it is better than using a safc.
Old Oct 24, 2003 | 04:21 PM
Sonny's Avatar
Default Re: S-AFC 2 or smc??? (mos)
SMC
Both units will alter timing because they are tricking the ECU (by modifying the MAP voltage input to the ECU) and thereby forcing it into a different area of the fuel/timing map.
For what you want to do, the SMC will work fine and it's a lot cheaper.
Sonny
Old Oct 24, 2003 | 04:53 PM
Hoodwinked's Avatar
Default Re: S-AFC 2 or smc??? (drvfast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drvfast &raquo;</TD></TR><TR><TD CLASS="quote">install a high pressure fuel pump for saftey. you can run the hack with your stock fuel pump. i recommed getting the walbro 255</TD></TR></TABLE>
werd
Old Oct 24, 2003 | 09:45 PM
slooogsr's Avatar
smc it is for me......... what model do u guys recommend?
Old Oct 24, 2003 | 10:18 PM
mattcalica's Avatar
the new safc is what i got...2 reasons, it monitors knock, so you know if your car is detonating, and it has two fuel maps that you can save to it...i think those are two really great features.
Old Oct 24, 2003 | 11:25 PM
turbod16y8's Avatar
Default Re: (mattcalica)
i got a smc plus for sale..
hondaNoober
Dec 22, 2015 10:34 AM
94siludeturbo
Jul 13, 2006 06:57 PM
wrXtian
Nov 29, 2002 10:41 PM
pelotudo
Sep 14, 2002 12:35 PM
shadowdawn
Apr 20, 2002 05:37 PM
