?'s about Intercooler placement?
Old Mar 28, 2004 | 01:18 PM
thaiphob's Avatar
Nikon!!!
Default ?'s about Intercooler placement?
i just test fitted my IC and it lines up perfectly. But i just wanted to know if i sould have something to support the bottom of it? currently its supported but bolts to the rebar and wondering if i need any other support?
Old Mar 28, 2004 | 02:08 PM
TurboCoop's Avatar
Default Re: ?'s about Intercooler placement? (thaiphob)
I got mine where I wanted it and even made a custom bracket to hold it in place, but the bracket looked stupid so I took it off and zip tied it in place. When you connect the charge pipes to it it stays in place fine. Put the bumper on first and see if it fits and how it looks. Mine was a little off center in these pics but I fixed it.
Old Mar 28, 2004 | 02:10 PM
Smooth-GSR's Avatar
You should be fine with just bolting it to the rebar, plus once you get the i'c pipes on it will hold.
Btw, what size intercooler is that, mine is going to look similar, just wondering if it fits with the bumper on without modification....
Old Mar 28, 2004 | 02:31 PM
Got Honda's Avatar
Default Re: ?'s about Intercooler placement? (Smooth-GSR)
that looks like the johnnyracecar.com intercooler. its a 30x6x2.5
Old Mar 28, 2004 | 04:53 PM
thaiphob's Avatar
Nikon!!!
Default Re: ?'s about Intercooler placement? (Got Honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Smooth-GSR &raquo;</TD></TR><TR><TD CLASS="quote">
Btw, what size intercooler is that, mine is going to look similar, just wondering if it fits with the bumper on without modification....</TD></TR></TABLE>
It fit without any modifications at all what got honda said is correct
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Got Honda &raquo;</TD></TR><TR><TD CLASS="quote">that looks like the johnnyracecar.com intercooler. its a 30x6x2.5</TD></TR></TABLE>
Old Mar 28, 2004 | 07:43 PM
HybridKOOP's Avatar
The I/C piping will have a real strong hold on it as well just like the member above said...
No other supports needed. Just make sure you used some sort of crush washer on the rebar mounting points...
Old Mar 28, 2004 | 09:39 PM
thaiphob's Avatar
Nikon!!!
Default Re: ?'s about Intercooler placement? (HybridKOOP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridKOOP &raquo;</TD></TR><TR><TD CLASS="quote">The I/C piping will have a real strong hold on it as well just like the member above said...
No other supports needed. Just make sure you used some sort of crush washer on the rebar mounting points... </TD></TR></TABLE>
yeah i learned that the hard way
Old Mar 28, 2004 | 10:21 PM
c jackson's Avatar
threes
looks good mark if you need any help or anything welded/fabbed hit me up.
Old Mar 28, 2004 | 10:43 PM
thaiphob's Avatar
Nikon!!!
Default Re: ?'s about Intercooler placement? (c jackson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by c jackson &raquo;</TD></TR><TR><TD CLASS="quote">looks good mark if you need any help or anything welded/fabbed hit me up. </TD></TR></TABLE>
cool thanx man. i got your # on speed dial
Buzzbomb
Sep 6, 2011 02:24 PM
dagle
Apr 12, 2009 11:16 AM
JordanCivic
Oct 4, 2006 10:46 PM
pissedoffsol
Aug 13, 2003 02:58 PM
s2k
Jan 14, 2003 06:58 PM
