Compression Test
Old Mar 12, 2010 | 03:42 PM
njmad's Avatar
Default Compression Test
ok honda tech need your help this time. i was preforming a compression test on my 97 acura integra gsr and I pulled out all the plugs, the fuel injector wires/clips. and just throw the spark plug wires to the side with out unplugging the dizzy wire. and did the test and now it wont start.. so did i blow my ignition coil?
Old Mar 12, 2010 | 04:02 PM
Lord Helmet's Avatar
Default Re: Compression Test
check your fuses and hopefully you put the plug wires in the correct firing order.
I still don't know why you pulled the injector wiring off. you pull the fuse off the underhood fuse box if you want the injectors to not squirt.
Old Mar 12, 2010 | 05:52 PM
njmad's Avatar
its all in order. and i just unclipped them so no fuel would go in
Old Mar 12, 2010 | 09:13 PM
mouab18c1's Avatar
You could of just disconnected the distributor without having to disconnect your injectors. Time to check for fuel and spark.
Old Mar 12, 2010 | 10:12 PM
danielblushtein's Avatar
YEP YEP all I do is just unhook the distributor main connection so I have no spark
Old Mar 13, 2010 | 01:42 PM
njmad's Avatar
so i shorted out something. fuses good. and so did i blow a coil??
Old Mar 13, 2010 | 10:42 PM
mrdeadman's Avatar
They let me pick
Is it trying to crank or no?
Old Mar 14, 2010 | 08:23 AM
njmad's Avatar
yeah it cranking over and getting fuel but no spark
Old Mar 14, 2010 | 11:47 AM
skipper28-DC's Avatar
Is it possible that the module is gone instead of the coil? CHECK
THE MODULE! i did the same thing after buying my car, turns out i somehow fried the module. . .
Old Mar 14, 2010 | 03:02 PM
Slow_import's Avatar
if you didnt disconect the dizzy connectors i'm pretty sure you shorted ur coil.
Old Mar 14, 2010 | 03:13 PM
njmad's Avatar
the module? you talking about the dizzy????
Old Mar 14, 2010 | 04:34 PM
mouab18c1's Avatar
Get your ignition coil tested and see if it shitted on you.
Old Mar 14, 2010 | 04:47 PM
njmad's Avatar
all right thanks honda tech
Old Mar 14, 2010 | 05:24 PM
racebum's Avatar
this is the correct answer, get a new coil and start the car
coil tests are not always accurate. bad coils will test good more than you might think
Old Mar 24, 2010 | 03:01 PM
TastyDragon's Avatar
damn lucky me i have the same problem cause my friend forgot to pull the distributor connector. how do you test if the coil and module are working or not?
Old Mar 24, 2010 | 03:16 PM
racebum's Avatar
there is no accurate way to test the coil besides using a known good one. team integra has a coil test but it's not 100% or even near. there is also a module test that escapes me. normally the coil fries when you do the compression test and don't unhook it. any $20 ebay coil will work fine for quite awhile. i know of one still going after 3 years
Old Mar 25, 2010 | 05:35 PM
njmad's Avatar
YEPP new coil did the job. thanks.^^^^^^its one of thos ebay 20 dollar ones. lmfao
brucepick
32
Nov 21, 2009 05:47 AM
95teg_ls
Apr 21, 2008 08:42 AM
steveo135
Jan 8, 2008 06:55 PM
A2gt35r
Sep 30, 2007 06:26 PM
Honda Hick
Feb 28, 2005 09:20 AM
