dead cycilendr HELP! tried everything !!
Old Feb 16, 2004 | 10:06 AM
DJone850's Avatar
Default dead cycilendr HELP! tried everything !!
my boy has a 91 crx hf and it has a dead cyciender #1 cyciender it gets spark but its dead .. and we did every thing from new injector to changeing spark plug wiers and all that good stuff .. need help its still dead
Old Feb 16, 2004 | 10:10 AM
LudeyKrus's Avatar
Do a compression test. Make sure it's getting spark. Check the injector and the fuel line/filter.
Old Feb 16, 2004 | 10:13 AM
DJone850's Avatar
Default Re: (LudeyKrus)
comprssron is good in all cylinder all match up , injectors are new , new fuel filter , new fuel lins and new plugs , has spark but it still dead in number 1...any thing elses we missed ???
Old Feb 16, 2004 | 10:16 AM
fearless_dsm's Avatar
Default Re: (StreetStars)
possible blown head gasket??was it running before?what happened when it stopped running?
Old Feb 16, 2004 | 10:18 AM
DJone850's Avatar
Default Re: (fearless_dsm)
its still running .... its just running off os 3 cylienders and no smoke and no over heating , so i asume its good ..
Old Feb 16, 2004 | 10:19 AM
LudeyKrus's Avatar
blown head gasket usually shows up on a compression test. hmmmm.......
try a leakdown test. If it's for sure getting spark, and you're sure the fuel's good, then something has to be bad w/ the compression. Or the fuel injector's clogged/dirty.
Old Feb 16, 2004 | 10:37 AM
DJone850's Avatar
ok thanx ill see what i can do
Old Feb 16, 2004 | 12:20 PM
JimBlake's Avatar
You changed injectors at that cylinder, right? Did you check if the circuit that powers the injector is OK? After trying/running for a bit, pull the plug. Is it wet with gas?
Old Feb 16, 2004 | 07:39 PM
DJone850's Avatar
Default Re: (JimBlake)
aiigth ill peep that and see , but yea the injector is new and i also put my stethascope to the injector and it was ticking like regular , but still its dead cylender .... im confused .. could it be the distribuber throwin a clod spark in to the block but still puting out spark in the pliug wire ??? idonno
Old Feb 16, 2004 | 08:42 PM
highcomp's Avatar
change the plug check the gapping try a differnt dizzy cap and rotor also the little filter on the injector.
Old Feb 16, 2004 | 11:11 PM
90Ninja
Guest
Posts: n/a
Default Re: (highcomp)
Also check all your wiring to that injector. Try another injector resistor box. If you have another available to you.
Old Feb 18, 2004 | 07:03 PM
bayarea13's Avatar
i can guarantee you if you have compression, fuel and spark you will have combustion. compression is straight forward and you said it was good. if you have injector drive and a pretty new injector you should be good. i would suspect an ellectrical missfire or no spark. put it on an igntion scope and see what you have.
Old Feb 18, 2004 | 09:09 PM
PnX-R's Avatar
Default Re: dead cycilendr HELP! tried everything !! (StreetStars)
Hmm.. Usually if I can't figure out a misfire problem and I know that I have compression, spark, and fuel, I take the Valve Cover off and see if the Exhaust Valve is opening while manually cranking the engine. Because air has to get out for the engine to make power.. (big air pump)
But that's just me..
Old Feb 18, 2004 | 09:21 PM
showtymers619's Avatar
* B A N N E D *
Default Re: dead cycilendr HELP! tried everything !! (PnX-R)
make sure your wires are correctly placed
Old Feb 18, 2004 | 09:42 PM
hondatim's Avatar
could have a broken rocker arm...
also, are you sure cam timing is OK? yes, this should affect all cylinders but just a suggestion.
If you are certain that spark and fuel are present and at correct timing, I would recommend removing valve cover and inspecting valvetrain.
again, just a thought...
Old Feb 25, 2004 | 03:30 PM
Billy Blaze's Avatar
Default Re: dead cycilendr HELP! tried everything !! (hondatim)
Do a cylinder leak down test. If for some reason theis cylinder is looseing enought compression for is to miss a leakdown test will pinpoint where the fault is. (Valve, rings, headgasket etc.) If that checks out okay, make sure your injectors are fireing. Use either a noid light or pull the fuel rail and injector assem out and crank the engine. If is sprays fuel you know its working. If that also checks out, and you have spark, I have seen a rod bearing cause a missfire. Not a dead cylinder, but a missfire.
Old Feb 25, 2004 | 09:12 PM
turbohondask's Avatar
Default Re: dead cycilendr HELP! tried everything !! (SoCalAutotech)
check the cap an rotor, is the spark plug good, and check the resitance on the wires
Old Feb 26, 2004 | 11:34 PM
* B A N N E D *
Default Re: dead cycilendr HELP! tried everything !! (turbohondask)
sometimes you might have a faulty sparkplug.. make sure you dont drop them in the hole
bassamillion
Honda Civic (2001 - 2005)
Jun 20, 2018 05:55 AM
SmaTTeRLegion
15
Sep 2, 2013 11:28 AM
mindslayer84
Nov 5, 2010 12:59 PM
85crxluke
Classic Hondas
Sep 19, 2008 10:47 PM
jamlude
Mar 8, 2008 08:54 AM
