Run without O2 sensor?
Old Dec 19, 2006 | 08:33 AM
vtec69's Avatar
Default Run without O2 sensor?
I was wondering if its possible to run the car without an o2 sensor?
Besides the CEL comeing on...are there any disadvantages?
The reason why im asking is because i want to monitor my AFR, and was planning on throwing a Wideband in my downpipe....just wondering if its neccesary to weld in a seperate bung
Thanks
-Brian
Old Dec 19, 2006 | 08:57 AM
93supercoupe's Avatar
Default Re: Run without O2 sensor? (vtec69)
U can turn off the O2 in ur ems so it wont throw a code.
Or u can use most widebands as a narrowband to also not throw a code.
Old Dec 19, 2006 | 10:00 AM
vtec69's Avatar
Default Re: Run without O2 sensor? (93supercoupe)
well its actually a WRX, and the EM im using i can turn off the CEL, i was just wondering if it will affect the performance of the car.......cause the car does have two O2 sensors, one in the header, before the turbo, and one after the turbo in the downpipe(where i would like to put the wideband)
Old Dec 19, 2006 | 12:14 PM
vtec69's Avatar
and from what i understand, u can run one o2 sensor in an OBD2 car as long as you leave one o2 sensor in that senses the fuel
Old Dec 19, 2006 | 01:27 PM
cheapmodz's Avatar
Are we talking removing both sensors or just one?
You really want that 1st one in there unless you like getting 10mpg.
Old Dec 19, 2006 | 01:50 PM
dunkd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec69 &raquo;</TD></TR><TR><TD CLASS="quote">well its actually a WRX, and the EM im using i can turn off the CEL, i was just wondering if it will affect the performance of the car.......cause the car does have two O2 sensors, one in the header, before the turbo, and one after the turbo in the downpipe(where i would like to put the wideband)</TD></TR></TABLE>
this is a honda board... hondas and subarus are different cars with different computers.
Old Dec 19, 2006 | 03:42 PM
LVB18Civic's Avatar
Default Re: Run without O2 sensor? (dunkd)
why not just weld in a new bung for your wideband? They are very cheap and then you don't have to worry about a CEL.
Old Dec 19, 2006 | 04:51 PM
92DAturboteg's Avatar
Default Re: Run without O2 sensor? (LVB18Civic)
I would'nt try it man!!!!
Old Dec 19, 2006 | 05:14 PM
EFvtec Yo!'s Avatar
a tuner told me that he could disable my stock o2 and that it would just read off of the map he tuned for me. Would that be safe?
Old Dec 20, 2006 | 03:53 AM
vtec69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dunkd &raquo;</TD></TR><TR><TD CLASS="quote">this is a honda board... hondas and subarus are different cars with different computers.</TD></TR></TABLE>
O i know
but the subaru boards were blocked at work, so i figured id try my luck on here first
and i meant leave one 02 sensor in the manifold, and put the WB in the DP,
and i learned before that the 02 in the manifold controls the fuel(which i will be keeping) and the one in the DP detects the cats effenc, so since im catless, its not problem
Nooget
13
Aug 14, 2010 08:12 PM
importdreamer
May 26, 2007 06:58 PM
mxl36o
Aug 4, 2006 06:09 PM
Phoenix_ITR
Jul 9, 2003 04:21 AM
Xerxes
Mar 4, 2002 05:17 PM
