o2 sensor slow response cel. WTF?
Went to autozone had a cel checked. They said it was a o2 sensor "slow response" Is right to assume this is simply a loose wire. I've thrown the o2 sensor crapped out code on my old car and this isn't the same. They couldn;t tell me the number on the code reader either for some reason. The car runs the same as before, smooth idle, good response, no bogging, no cut outs, and no change in fuel economy.
1 Post
Re: o2 sensor slow response cel. WTF? (importdreamer)
A slow response can be...
An O2 sensor needs to be hot to work, That is why the manufactures have now installed O2 sensor heaters. So they will work sooner than if they relied on just the exhaust to warm them up. Your's might be slow to warm up , or..
The O2 sensor is suppose to move from rich to lean in a cycle of 8 - 10 times a second. Your's might be doing a slower cycle say 4 - 6 times a second.
Either way probably it needs to be replaced and it is not a loose connection because the computer is seeing it.
Hope this help's
Hope this help's
Mr. Indecisive
Re: o2 sensor slow response cel. WTF? (thesmogman)
Ur o2 sensor is starting to go.. its not completely gone yet, but will be soon. You will see your gas milage get worse and worse as the sensor completely *****. Pick up a new one and you'll be good
Re: o2 sensor slow response cel. WTF? (EJ8VTEC)
Can I eliminate the secondary o2 sensor by running a patch wire to the primary on the header? It only like less than a foot away. Has anyone ever done this?
mxl36o
08-04-2006 06:09 PM
agent marlon
01-29-2003 01:22 PM
