Rods and Pistons for good boost numbers
Old 06-09-2003, 12:31 PM
ekb16turbo's Avatar
Default Rods and Pistons for good boost numbers
I came across a set of JE pistons Standard Bore 9:1 and a set of Eagle rods and wondering what kind of boost this set up could handle I want to boost quite a bit but still be streetable (the car will normally sit in garage except for weekend nights and nice days) when needed but dont want to upgrade internals again after I find a daily clunker.
Old 06-09-2003, 12:33 PM
b18bturbo's Avatar
Default Re: Rods and Pistons for good boost numbers (ekb16turbo)
not a bad setup i would run it with a sleeved block and you should have mucho fun
Old 06-09-2003, 12:34 PM
ekb16turbo's Avatar
Default Re: Rods and Pistons for good boost numbers (b18bturbo)
do you know what kinda psi I could run like numbers?
Old 06-09-2003, 12:43 PM
b18bturbo's Avatar
with that setup i would go about 15-20psi safely
Old 06-09-2003, 12:44 PM
ekb16turbo's Avatar
is that with or without the sleeves?
Old 06-09-2003, 12:51 PM
b18bturbo's Avatar
without sleeves i would go probably max of 15
Old 06-12-2003, 10:41 PM
TurboTeG4's Avatar
This will give good fast spool up with 9:1??
Old 06-12-2003, 10:58 PM
turbod16y8's Avatar
Default Re: Rods and Pistons for good boost numbers (turbocivic4)
15 psi with a good fuel management.. what engine is this for?
Old 06-13-2003, 12:08 AM
blackANESE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbocivic4 &raquo;</TD></TR><TR><TD CLASS="quote">This will give good fast spool up with 9:1??</TD></TR></TABLE>
with what turbo?
Old 06-13-2003, 07:19 PM
TurboTeG4's Avatar
Default Re: Rods and Pistons for good boost numbers (blackANESE)
for a t3/t4oe 57 trim, .63a/r exhaust housing, with a stage 3 blade turbo , **** one more hour for auction if someone could answer would be mean
Old 06-13-2003, 07:24 PM
TurboTeG4's Avatar
You think used engines will need to rebore or they are mostly in good shape to get the stock bore pistons again. Cause i dont got my engine yet but i can get some stock bore pistons for a b18c1 engine that i will get later.
Old 06-13-2003, 07:51 PM
New User
Boostfed's Avatar
.5 mm overbore usually is needed alot of times used motors will have the cylinders egg shaped or ovaled over time so go overbore to be safe and you will have a perfect bore and hone from a machine shop
Mechman456
Honda Civic (2006 - 2015)
11-06-2007 11:25 AM
program
11-05-2005 05:00 PM
skellator_thoj
05-19-2003 05:08 PM
adhana2
05-10-2003 05:02 PM
Quick Reply: Rods and Pistons for good boost numbers
