restrictive downpipe=backpressure???
Old Feb 17, 2003 | 01:38 PM
Bongnak's Avatar
Default restrictive downpipe=backpressure???
man this sucks...after installing the turbo and smc the car idles extremely high...so i took the charge pipes off and put the stock injectors back in and it still idles at 3k...you guys think its my downpipe? http://www.imagestation.com/picture/...0/fca7a522.jpg will that cause a lot of back pressure and idle the car at 3k??
Old Feb 17, 2003 | 02:00 PM
thenick's Avatar
Default Re: restrictive downpipe=backpressure??? (Bongnak)
i wont judge the book by its cover, but what diameter piping are you using? ideally wouldnt you wanna run a 2.5" to 3" downpipe?
[Modified by ixiblindixi, 11:01 PM 2/17/2003]
Old Feb 17, 2003 | 02:10 PM
turbod16y8's Avatar
Default Re: restrictive downpipe=backpressure??? (ixiblindixi)
it cant be the downpipe. check your wiring.
Old Feb 17, 2003 | 02:31 PM
Bongnak's Avatar
Default Re: restrictive downpipe=backpressure??? (turbod16y8)
yeah checked it many times. i also have the ecu pinout for the pm6 and its correct....oh can it be my injectors....i have low impeadence rx7 460's and have the stock crx resistor pack in line with the wiring, are my resistance levels correct with the ecu and smc or injectors...thanks this is stressing me out im putting the stock mani back on i need the car
Old Feb 17, 2003 | 02:43 PM
thenick's Avatar
https://honda-tech.com/zerothread?id=415342
Old Feb 17, 2003 | 03:13 PM
evoeone's Avatar
now thats a ghetto DP, you take the cake with that one, but if i works it works
Old Feb 17, 2003 | 07:13 PM
Finland's Avatar
That downpipe looks tremendously restrictive and completely inconducive to flow. Start over. Buy a flange from Turbonetics, some pieces of mandrel bent stainless from Kinsler Fuel Injection, and have some one weld you a proper pipe. I have some pics if they will help you.
Old Feb 17, 2003 | 07:44 PM
Bongnak's Avatar
Default Re: restrictive downpipe=backpressure??? (acurate1)
yeah thanks alot for the links stupid stupid me , soo close
DJ 2501
20
Jun 28, 2013 07:11 PM
EthanR
Engine Management and Tuning
May 15, 2010 08:27 PM
baboracus
Jun 27, 2007 05:13 PM
blackhbkid
Jan 16, 2006 12:07 AM
fjt
Oct 7, 2004 12:46 PM
