removing rust from fuel injectors
Old Jun 28, 2003 | 12:28 AM
ID_ten_T's Avatar
Default removing rust from fuel injectors
i just picked up some dsm 450s from the junkyard. problem is they are rusted on the outside. so i was wondering, will this cause a problem if i install them? also, if i wanted to try to remove the rust, what would be the best way to do this without damaging the injectors? thanks in advance.
Old Jun 28, 2003 | 09:15 AM
GreddySi99's Avatar
Default Re: removing rust from fuel injectors (ID_ten_T)
the rust on the outside will not hurt them. however I would send them to rc to get flow benched. clean them with a dremel and a fine wire brush then put some kind of clearcoat on them so they dont rust again!! hope that helps man
Old Jun 28, 2003 | 03:49 PM
ID_ten_T's Avatar
Default Re: removing rust from fuel injectors (intercooledJRSC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by intercooledJRSC &raquo;</TD></TR><TR><TD CLASS="quote">the rust on the outside will not hurt them. however I would send them to rc to get flow benched. clean them with a dremel and a fine wire brush then put some kind of clearcoat on them so they dont rust again!! hope that helps man</TD></TR></TABLE>
thanks for the info. with the clearcoat, what do you recommend? i was thinking something simple like in an aerosol can. would this work with the heat of the engine? if not, what do you recommend? thanks.
Old Jun 28, 2003 | 10:58 PM
keebler65's Avatar
yeah that would work fine. between the insulation of the injector from the manifold (gasket) and the fact that fuel is usually cold, they wont get hot.
Old Jun 29, 2003 | 07:28 AM
ID_ten_T's Avatar
Default Re: removing rust from fuel injectors (keebler65)
so just tape off the top, bottom, and plug and then spray away? (sorry if this is a little noob, i just wanna make sure i do it right the first time and dont wanna mess up these injectors). thanks.
Old Jul 2, 2003 | 08:32 PM
ID_ten_T's Avatar
anyone? like i said, i just dont wanna screw this up. thanks.
Old Sep 23, 2003 | 08:33 PM
cornhusker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ID_ten_T &raquo;</TD></TR><TR><TD CLASS="quote">so just tape off the top, bottom, and plug and then spray away? (sorry if this is a little noob, i just wanna make sure i do it right the first time and dont wanna mess up these injectors). thanks.</TD></TR></TABLE>
Did this work for you? Anyone have any thoughts on if spray paint will work to prevent rust? Or should I get the brush on stuff? TIA.
GODSPEED33
Dec 24, 2006 12:03 PM
kornerk12
Oct 15, 2006 01:17 PM
Under_Pressure
Oct 11, 2005 03:47 PM
213374U
Aug 5, 2005 09:48 AM
SCsol
Aug 5, 2002 10:29 AM
