Reliable D Boost???
Old Jan 23, 2008 | 06:00 PM
  #26
Newt Dog's Avatar
Default Re: (CodyC142)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CodyC142 &raquo;</TD></TR><TR><TD CLASS="quote"> While I have some play money should I sleeve it on the safe side, incase the addiction grows to strong to stop at 300whp?
Also, what should I do as far as clutch / FLywheel set up. I cant imagine the stock clutch will hold up to much abuse at 300whp. I figure I might as well start shopping before that problem ever comes up. Any thoughts / suggestions are more than welcomed.
[/i]</TD></TR></TABLE>
Lol.. We are close to 500hp on stock sleeves. Everyone told me it would not last 15 minutes. It's lasted me 2 years so far. My car is a track car and does not see the street much though. If driven as a daily, I wouldnt go anymore than 375hp on stock sleeves. Besides, Anything more than that is not really needed on the streets anyway. We are running an Action 2md clutch with no problems at all..
Old Jan 24, 2008 | 07:47 AM
  #27
wernhersey's Avatar
Default Re: (Newt Dog)
Awsome info Guys!
What do you guys think about lightining the crank a little. Will the loss of wate effect the longevity of the bearings? One more question for now. A block guard is really up in the air right now. I really need to know what the pros and cons are of using one. I understand the main goal of a blockguard. But what are some of the things most people don't understand about block guards? I realize that there is a heat issue but what excatly is the issue? How can the issue be resolved and still run a guard?
Thanks for all of your help guys!
Old Jan 24, 2008 | 08:44 AM
  #28
HiProfile's Avatar
Default Re: (wernhersey)
Well the issues really can't be resolved. You either put it at the very top of the sleeve and reduce cooling capacity, or put it lower/drill more holes in it and severely reduce its effectiveness. I've also seen not just block-guarded sleeves CRACK, but I've also seen it happen on FILLED blocks (filled 100% with aluminum epoxy). Cracks will want to start at the top of the sleeve, which is where it heats up the most too. W/o the block guard at the top, its basicly useless.
The bearings won't be harmed by a lighter crank, unless you go crazy with it. Crazy would entail a 5lb flywheel, 3-puck double-diaphragm 'stage3+' clutch or dual-plate CF clutch, and lightened crank pulley.
If you're really woried about those 2 issues, I'd suggest you not go with a D-series. You can build/boost a B18B for about the same price, but get another 30-60whp 'safely' on the stock sleeves due to displacement, and get an ATI harmonic dampener. IMO D16's are most effective when you don't pour your life savings into them.
Old Jan 24, 2008 | 06:55 PM
  #29
wompmaster's Avatar
Default Re: (quicksilver1689)
what is a sc61
Old Jan 25, 2008 | 03:13 AM
  #30
Newt Dog's Avatar
Default Re: (wompmaster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wompmaster &raquo;</TD></TR><TR><TD CLASS="quote">what is a sc61</TD></TR></TABLE>
Its a dishwasher!!
Old Jan 25, 2008 | 07:15 AM
  #31
95jeremie's Avatar
Originally Posted by wernhersey
1.Should we have it re-sleeved with stock sleeves?
2.Is there any way to put equal length cv axles in it, like the b-series?
3.What would you guys suggest we do with the tranny?
4.Will a stock ex hold up to these numbers?
5.What intake manifold would be the best performing, without spending crazy money?
1.NO
2.NO
3.OBX lsd but make sure to rebuild it prior to install https://honda-tech.com/zerothread?id=1714724
that and new tranny fluid and you should be good to go the ex tranny is solid
4.Yes
5.pick up the victor X by Edelbrock if your looking for mid range or skunk 2 pro series if you looking for better top end.
What would you suggest for a bore. The cylinders are in running condition so should I go with a .20 or should I just go as much as possible?
.20 is good for your DD. as was mentioned you don't want to go to big
Originally Posted by trickeng
never go as big as possible because if you melt a piston you'll have to sleeve or buy a new block.
.20(.5mm) over for now.
Originally Posted by CodyC142
While I have some play money should I sleeve it on the safe side, in case the addiction grows to strong to stop at 300whp?
Also, what should I do as far as clutch / flywheel set up.
you can do anything you want to do
however sleeving is NOT required
clutch= action 2md most definitely they are the ****. that is what I'm running and it was suggested to me by rota... trust that guy he knows his ****
as far as flywheel stay stock or not to far off no lighter than 10 lb's for my suggestion
by reducing the mass you will have to rev it to start off. I run a 10 lb fly with no problems. however people look at me crazy sometimes whenever I'm trying to start off on a hill or something like that
A block guard is really up in the air right now. I really need to know what the pros and cons are of using one. I understand the main goal of a blockguard. But what are some of the things most people don't understand about block guards? I realize that there is a heat issue but what exactly is the issue? How can the issue be resolved and still run a guard?
from my research and i would like to stress that it is only research so don't flame
block guards create hot spots on the sleeves
this causes them to overheat and damage the rings in most cases
on a daily driver where you might have that...
I need it to be reliable enough to hop on the interstate and drive 14 hours home if need be.
IMHO that would be that would cause a lot of pressure on you entire cooling system
a block guard definitely won't help your cooling in fact it will hurt it. so just say no
Originally Posted by wompmaster
what is a sc61
https://honda-tech.com/zerosearch
Hope that this helps
Old Jan 25, 2008 | 07:50 AM
  #32
95jeremie's Avatar
https://honda-tech.com/zerothread?id=1958899
another 300whp build asking about block guard
http://forums.evans-tuning.com/viewtopic.php?t=389
https://honda-tech.com/zerothread?id=1495885
https://honda-tech.com/zerothread?id=1260938
Old Jan 25, 2008 | 10:52 AM
  #33
wernhersey's Avatar
Default Re: (95jeremie)
95jeremie is the dude with all the answers. Thanks bro that really cleared some things up for me. I think that this build will be cheaper than we had anticipated. thanks again for all of your help guys. Im sure I will have some more questions in the near future!
hhardell
Feb 25, 2013 08:01 AM
ChrisHinds
May 9, 2010 05:38 PM
crxpro
Dec 4, 2008 04:54 AM
funkified
Jan 10, 2007 03:06 PM
hatchinprogress
20
Sep 20, 2005 06:59 AM
