Building a d16z6 for boost
Old Feb 20, 2013 | 08:34 PM
hhardell's Avatar
Default Building a d16z6 for boost
I have a z6 head and want to build a z6 block to run some psi... Would like to run around 16psi... What will be required to handle that pressure? I know sleeping is recommended but a shop here in Sioux Falls where I live developed their own cylinder stabilization system that has been proven to work extremely well under high boost without sleeping.. But as for pistons, rods, bearings, valve train etc what all should I invest in.. I'm building it myself but I want to try to keep the motor aspect of the build between 2 or 3k... Any suggestions appreciated
Old Feb 20, 2013 | 09:08 PM
OneBadTurboCRV
Guest
Posts: n/a
Default Re: Building a d16z6 for boost
PSI, boost, ect all are completely meaningless without EXACT turbo.
Knowing what avenue is good for you we need your budget (which we have), wheel horsepower goals, and purpose of the car.
Also, you have to sleep some time. No way around it, part of being human.
Old Feb 20, 2013 | 11:48 PM
wantboost's Avatar
Who is Mr Robot?
We need a power goal before we can even begin to help
I will say this, you can't make much more than 225ish HP without forged rods and pistons, then you need ARP headstuds, etc, etc, the list is endless
Old Feb 21, 2013 | 03:20 AM
doctorake's Avatar
If you loved me, you'd all sell me your magic cards to me today
Veteran: Coast Guard
Community Builder
Please read through the FAQs and research more.
Old Feb 21, 2013 | 10:27 AM
Schister66's Avatar
Man U FTW
Read the FAQs, first and foremost.
If you keep your goals under 240whp, you can boost the stock engine (at whatever psi you want, so long as it makes under 240whp). If that isn't enough, a simple Vitara/Eagle build is an affordable way to break into the 300-400whp range; however, the compression ratio on Vitaras isnt ideal. Your best option is a Wiseco, CP, JE, etc forged piston with either Eagle or FJT rods (so that your compression is in the 9.5-10:1 range rather than the 8:1 or whatever with Vitaras), but this option is obviously the most expensive of the three.
Once you figure out your goals and budget, you need to figure out which existing setup works for you OR do what most of us do and build a setup from the ground up. Once you've learned enough to comprehend what needs to be done, finding and buying the parts is easy. Start by reading and researching...otherwise you're always at the mercy of the opinions of others
lol. I wanna get my engine sleePed
Old Feb 23, 2013 | 05:51 PM
hhardell's Avatar
Well i want to be around 350whp. I meant sleeving in my original post. but yeah, i am looking at a Weisco Forged piston/ Eagle H-beam forged rods combo on ebay for like $819. comes with the wrist pins and piston rings also.. I dont know what kind of main and rod bearings i will need.. Are Clevites good or is there something better.. I was also curious about what i need to do with my head, valvetrain, fuel etc.
Old Feb 23, 2013 | 06:08 PM
OneBadTurboCRV
Guest
Posts: n/a
Stock is fine for valvetrain and OEM is best for bearings. For fuel you will want 550+cc injectors and a Walbro 255 fuel pump. For that low of horsepower you don't need much other than forged internals and a properly sized turbo.
Old Feb 24, 2013 | 11:30 AM
Schister66's Avatar
Man U FTW
OEM Bearings are great, but ACL works just as well. If you have any maching work done on the crank, you'll need ACL bearings as there is no OEM oversized option (at least for B series @ +.25mm).
You dont need to sleeve it. I got what you were saying, but we had to give you **** about it. The stock sleeves will be fine into the middle 400s.
550cc injectors would cut it, but i would go with 720s (or something around that size) for gasoline. If you're running e85, you'll need to go bigger ~880-1000cc
Old Feb 24, 2013 | 08:32 PM
Hidenplanvew's Avatar
Read up on Vitara builds, 300-400 bucks and you can make good power. I was making 440whp using vitara pistons and eagle rods and stock sleeves. I would look at dseries.org theres lots of d16 builds over there...
Without lots of sleeping you shouldnt be driving a car, let alone anything over 250whp
Old Feb 24, 2013 | 08:54 PM
exwillis95's Avatar
im working on the same project and im going with wiseco/eagle setup and acl bearings and arp head studs from what ive read and heard its a good setup for stock sleeves when running boost.. only thing idk about is what to do with head work???
Old Feb 25, 2013 | 03:11 AM
blackeg's Avatar
You don't need to spend a lot on headwork, maybe an intake manifold and if ur really feeling jazzy a cam. Money is better spent on pistons/rods and for the z6 maybe a d2b conversion or a tranny with altered gear ratios. The z6 trans is long and will seem laggy with a decent sized turbo that can make higher hp numbers.
Old Feb 25, 2013 | 07:56 AM
MELEN2120's Avatar
bbuummpp!!! good luck with your d16. but if intarested i have a piston rod combo for sale cp and eagle.550 shipp new pistons new rings new rods 77mm 9:1 comp
Old Feb 25, 2013 | 08:01 AM
MELEN2120's Avatar
and you can allways do what i did 6262 turbo, sleeves block, piston rods, head studs ,stock head only valve spring and retainers ,cop set up ,ported oil pump ,acl race bearings ,a good balence of the rotating assembly ,and a strong clutch and working on a d2b kit (if i sell the piston and rods will get d2b kit next and last lol )ooohhhh sorry and a good intake mani (i got a gato intake a bit on the high end side but a great part wold recoment to eny one )
zcme
May 14, 2009 07:51 AM
Black95CivicEx
Dec 30, 2008 02:11 PM
crxpro
Dec 4, 2008 04:54 AM
blkcoupe94
23
Jun 22, 2005 07:58 PM
POE
Oct 29, 2003 10:14 AM
