Recommended Oil Pump for LS-T
Old Jun 10, 2006 | 07:52 AM
astralshadow's Avatar
Default Recommended Oil Pump for LS-T
I searched and searched but couldn't find anything with a solid explanation. I'm rebuilding an LS Block and will run it for a while before I can afford to turbo it. Will the stock LS Oil pump last me with a turbo setup or would it be advantageous to just swap it out with an ITR/GSR pump now since the block is disassembled? Is there any drawback to running a higher flowing pump before the motor is turboed?
I don't see why there would be a problem, and since oil pumps have a tendency to fail anyway....
Thanks for the input!
Old Jun 10, 2006 | 08:06 AM
DRAGLS's Avatar
Default Re: Recommended Oil Pump for LS-T (astralshadow)
stick with the stock one
Old Jun 10, 2006 | 12:38 PM
qfast817's Avatar
go typer or gsr
Old Jun 11, 2006 | 07:07 AM
Default Re: Recommended Oil Pump for LS-T (qfast817)
but why?
Old Jun 11, 2006 | 08:24 AM
rextec's Avatar
96+ ls = gsr, type r fyi
Old Jun 11, 2006 | 10:44 AM
3a_eg_hatch's Avatar
Default Re: (rextec)
there are more teeth on a vtec pump for the belt then a ls pump
Old Jun 11, 2006 | 04:11 PM
B18C Turbo's Avatar
exactly, the dumbest thing you can do during your build is re using the oil oil pump, trust me trust me trust me please. If anything please trust me, I did it, it worked, and then it seized after 4k miles. $2000 down the drain for a retarded $100 part. Get a GSR/Type R oil pump right from honda for $100 obd-2 96+ pump. You need hondabond as well to mount it, use brand new bolts from Honda because sometimes they can be warped and not go back in coreectly, these bolts are about .50 each from Honda and theres about 6-8. Dont skimp out! Trust me on this please, I would hate to see you build a sick bottom end and then your old oil pump decides to fail with a fresh bottom end.
Old Jun 11, 2006 | 04:19 PM
Dc4turbo408's Avatar
Default Re: (B18C Turbo)
I would do what he said.. Everythough my stock one is doing just fine..
Old Jun 11, 2006 | 06:32 PM
akstunt600's Avatar
get a gsr its a constant 4-8psi more through out the rev range
Old Jun 12, 2006 | 08:53 AM
Default Re:
Thanks for the responses guys, I'm looking into buying the gsr pump
Old Jun 12, 2006 | 09:56 AM
Blackack26's Avatar
Default Re: (3a_eg_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3a_eg_hatch &raquo;</TD></TR><TR><TD CLASS="quote">there are more teeth on a vtec pump for the belt then a ls pump</TD></TR></TABLE>
that would be the water pump.
And yeah as already mentioned the 96+ oil pumps are the same (ls, gsr, itr), it will do you fine.
Old Jun 12, 2006 | 10:00 AM
teamsoy1320's Avatar
itr just so you can so you have one...but u really need a gsr pump and you will be fine
Old Jun 12, 2006 | 10:18 AM
JDMs1eeper's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rextec &raquo;</TD></TR><TR><TD CLASS="quote">96+ ls = gsr, type r fyi</TD></TR></TABLE>
yup, all pumps are the same from 96+
Old Jun 12, 2006 | 11:10 AM
NJcoupe's Avatar
Default Re: (JDMs1eeper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMs1eeper &raquo;</TD></TR><TR><TD CLASS="quote">yup, all pumps are the same from 96+ </TD></TR></TABLE>
But remember, if your using a 96+ oil pump on a Pre 96 Motor, You have to find/buy the 96+ timing covers.
Old Jun 12, 2006 | 06:38 PM
JDMs1eeper's Avatar
Default Re: (dxcoupe.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dxcoupe. &raquo;</TD></TR><TR><TD CLASS="quote">But remember, if your using a 96+ oil pump on a Pre 96 Motor, You have to find/buy the 96+ timing covers.</TD></TR></TABLE>
very true
keychild486
Apr 2, 2008 04:58 PM
hydroflip
Aug 6, 2007 02:07 PM
BuddhaSiR
Aug 16, 2006 11:29 AM
Mugencrxsir1
Apr 25, 2006 03:02 PM
Gonzo
Feb 14, 2002 03:37 PM
