rebuilding the bottom end...?
Old Sep 17, 2002 | 12:16 PM
Doogie Howser's Avatar
Default rebuilding the bottom end...?
my gsr has 125,000 and im planing on turboing it, right now the compression is perfect and im not planing on running a lot of boost. I think im going to still rebuild though before i put the turbo on. What setup should i go with and what are some good companys to work with. Also what would you recomend for only 10psi with a t3/t4. Im thinking just je pistions and forged rods. Should i also have my blocked sleeved?? thanks for the help, if anyone has a website for a good company with some price it would be helpfull
Old Sep 18, 2002 | 05:54 PM
Default Re: rebuilding the bottom end...? (mlambrecht)
anyone?
Old Sep 18, 2002 | 06:01 PM
93LSivic's Avatar
Wiseco, Eagle, and Cometic. If you want sleeves I carry Darton's. For only 10psi you should just get a headgasket and some good fuel management.....but a built bottom end would be key!
I can get you good prices.
Old Sep 18, 2002 | 06:15 PM
Default Re: rebuilding the bottom end...? (93LSivic)
do you think ill be ok consider the mileage on my motor, my compression was 200,200,205,200
[Modified by mlambrecht, 3:21 AM 9/19/2002]
Old Sep 18, 2002 | 06:19 PM
93LSivic's Avatar
First things first. Do a compression and leakdown test on the motor. This will tell you if its a good idea to boost on the stock bottome end.
MyEGisBad
Jan 19, 2011 10:12 AM
kory97
Dec 29, 2006 02:14 AM
tobe1424
Aug 16, 2005 01:04 PM
wrXtian
Oct 17, 2002 10:16 AM
mex
Nov 30, 2001 05:39 PM
