Turbo B18A compression ?
Old Jan 17, 2011 | 08:51 PM
MyEGisBad's Avatar
Default Turbo B18A compression ?
I'm getting ready to order pistons/cams the whole she-bang by the months end. Since I'm building for boost on a Garret Super 60 series I'm not sure how low of compression I should go for with the pistons. Obviously lower compression for turbo applications and higher for NA, I'm aiming for 250whp minimum so, my question in point would be whats the lowest Comp ratio that I should go for without over-doing it and actually doing more harm than good? Thanks!
Old Jan 17, 2011 | 09:11 PM
JdmTypeRdc2's Avatar
Default Re: Turbo B18A compression ?
For 250whp, stock compression is fine.
Old Jan 17, 2011 | 09:13 PM
Stopsign32v's Avatar
Loved
Why are you building the motor if you only plan to run 250whp? A stock rebuild with better rings would be my choice for only 250whp.
Old Jan 19, 2011 | 10:12 AM
BigMike0147's Avatar
I'm in the same boat as MyEGisBad. I'm looking to rebuild my second motor, but I'm going to daily it. I was shooting for the same power goal because I want it to be reliable. It looks like the concensus is to go back with a factory rebuild for anywhere between 250-300whp?? Not tryin to jack thread, just wanting to get it sorted out.
civic-r11
Mar 31, 2009 12:04 PM
jdmstreethatch
Feb 5, 2005 09:21 AM
Doug684
Dec 30, 2003 09:59 AM
