compression?
Old Oct 16, 2002 | 04:53 PM
wrXtian's Avatar
Default compression?
just curious what kinda compression u guys are running w/ ur turbo cars? i was considering going from my stock ls 9.2 to maybe a stock gsr piston head which i think raises it up to a 10.1? i'm exactly but my friends are saying that's too high.. i was then again thinking about all those gsr's running their stock compression on boost and seem to run ok.. only thing i'm thinkin about is higher compression = more power.. witht he pistons i do plan on getting some rods.. i was considering the crower connecting rods unless u guys think there are better ones out? i have a stock B18a engine in my car.. any info would help.. thanks
Old Oct 16, 2002 | 05:02 PM
ekb18c's Avatar
Default Re: compression? (xjdm94x)
i ran on 10:1 compression @ 14psi on pump gas. A car with higher compression running the same amt of boost as compared to a car running 9.2:1, will yield more power.
Old Oct 16, 2002 | 05:33 PM
Pelican's Avatar
I just saw this the other day,
LS Rod :5.394" and fraile big end
GSR Rod: 5.429" and a lot beefier Big end
Pretty noticeable, HTH
My favorites are Carillo, Ferrea and Oliver
But High Comp Turbo car is the ****. Have to do pump gas.....Lower the boost. Still have a decent NA car instead of 9:1 slug
Old Oct 16, 2002 | 05:54 PM
wanabecivicex's Avatar
Default Re: compression? (Pelican)
ill be running 8.5 when im done with my car
Old Oct 16, 2002 | 09:55 PM
wrXtian's Avatar
Default Re: compression? (wanabecivicex)
i basically just wanted to know if 10.1 is gonna be safe as long as i get stronger rods daily driven
Old Oct 17, 2002 | 06:04 AM
ekb18c's Avatar
It all depends on how much boost you are going to put out. If your going to push out 7psi then you wont need pistons or rods, it wouldnt hurt but you really dont need it. If however you going to be pushing over 10psi then get yourself rods and pistons.
10:1 compression ISNT too high for a daily driver running 7-8psi.
Old Oct 17, 2002 | 06:58 AM
MatT3T4's Avatar
Default Re: compression? (ekb18c)
Dude you won't have any problems as long as your setup is right. I've run 14psi on 10.4:1 on pump gas (1/4 mile bursts...not long distances, of course). 10.0:1 is not high at all, I wouldn't sweat it.
Old Oct 17, 2002 | 09:19 AM
98civicEX's Avatar
Default Re: compression? (MatT3T4)
you guys refering to SOHC or DOHC? if not SOHC, does this still apply?
Old Oct 17, 2002 | 10:16 AM
MatT3T4's Avatar
Default Re: compression? (98civicEX)
kinda in theory, but not in reality...simply because the SOHC internals aren't as strong as the DOHC internals...so they can't really handle the stresses the DOHC can
99siRACER
Jan 3, 2012 12:20 AM
LERRY
Apr 8, 2008 08:28 AM
CivicDude2k4
18
Oct 8, 2006 09:13 PM
Drizzo
Aug 16, 2005 02:00 PM
Soon_2b_evil
Nov 16, 2003 07:41 PM
