RC 550 O Ring?
Old Aug 27, 2007 | 08:26 AM
EX-T's Avatar
Default RC 550 O Ring?
I have a built d16y8 and got some RC 550s used and they didn't come with the o ring that goes into the intake manifold so I used the ones off my stock injectors.
My problem is that this area of the RC injector is slightly bigger than the same area of the stock injector. The stock o ring fits on the RC injector but the injector doesn't fit into the intake manifold. 3 of the 4 injectors are fine but one of them is leaking ever so slightly.
Does anyone know where I can get the right o ring so that the injectors fit into the intake manifold?
Old Aug 27, 2007 | 08:44 AM
Boostedb20EH2's Avatar
Default Re: RC 550 O Ring? (EX-T)
I used a dremel.
Old Aug 27, 2007 | 11:21 AM
EX-T's Avatar
Default Re: RC 550 O Ring? (Boostedb20EH2)
So you just woller out the stock o ring a little with a dremel tool?
Old Aug 27, 2007 | 11:22 AM
DaveF's Avatar
if you need the oem style seals that fit the intake manifold, you can usually pick up a kit of them at NAPA.
Old Aug 27, 2007 | 02:10 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EX-T &raquo;</TD></TR><TR><TD CLASS="quote">So you just woller out the stock o ring a little with a dremel tool?</TD></TR></TABLE>
Yep, carefully. I've broke one before using the dremel (shitty sandpaper broke)
Old Aug 27, 2007 | 02:49 PM
PrecisionH23a's Avatar
Yep... it should take about 5-10min. Just check the sizing frequently so you don't remove too much material.
Old Aug 27, 2007 | 03:58 PM
blaze the chemi's Avatar
Default Re: RC 550 O Ring? (PrecisionH23a)
Or you could just buy the D16Z6 o rings since they are OBD1 size just like the RC's. At least it worked for me on the B16 intake manifold for my EM1. I bought '94 B series o-rings and wallah..perfect fit. The Acura dealership was actually cheaper than autozone because autozone sells a kit when I only needed on part of the kit
Old Aug 27, 2007 | 04:45 PM
Crx Jimmy's Avatar
Use the sanding drum on the dremel, works like a charm
Old Aug 27, 2007 | 05:40 PM
willyboyK20's Avatar
on my y8 with 550cc's I actually got a razor blade and CAREFULLY cut the inside material out of the seal. I did it until it fit snug.
Old Aug 28, 2007 | 02:06 PM
dpetro1's Avatar
Default Re: RC 550 O Ring? (willyboyK20)
i installed my RC550's according to these instructions from RC. http://tiger.towson.edu/~dpetro1/rc550.doc
you can see towards the bottom it says that the injectors should sit on top of the seal. mine have been like that for 2 years with no issues. it seems like dremeling works as well but isnt necessary.
Old Aug 29, 2007 | 09:35 AM
EX-T's Avatar
Default Re: RC 550 O Ring? (dpetro1)
I'm gonna check out those instructions when I get home but on the other hand...will OBD1 O rings solve my problem?
nonpoint986
10
Jul 14, 2010 05:07 AM
96 GSR-T
Nov 23, 2007 07:22 PM
jtracing919
Mar 23, 2006 04:50 AM
JDM_Ej
Aug 8, 2005 12:32 PM
Blackack26
Feb 20, 2004 10:59 AM
