Can I use OEM Injector Seals on RC Injectors?
Re: Can I use OEM Injector Seals on RC Injectors? (96 GSR-T)
The outside diameter is the same and I believe the inside is as well. If not you should easily be able to bore the OEM seals to fit.
-platinum
-platinum
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96 GSR-T »</TD></TR><TR><TD CLASS="quote">As stated, will there be any issues, talking about the intake manifold seal
Thanks</TD></TR></TABLE>
I used them on my RC 750's without a problem.
thanks fella's, Platinum.... how could I bore an injector seal? they are soft plastic not hard so drilling would be impossible I would think.
Re: (96 GSR-T)
i used my dremel with a sanding drum on it. My inside diameter needed to be enlarged to fit my rc injectors. depending on which style u have they may fit into your stock grommets just fine
Re: (tannerLSt)
You can also goto NAPA and get a injector seal kit and it comes with multiple size injector seals. Alot used to go this route when running DSM 450's
Good luck..
-platinum
Good luck..
-platinum
