Installing RC injectors
Old Feb 19, 2004 | 07:20 PM
Blackack26's Avatar
Default Installing RC injectors
Ok, ive tried searching and I found many mixed reviews on which o-ring seals to use and how to go about getting a good seal. I've taken some pictures of what i'm dealing with here, the car is a 92 DA if that makes a diference. The injectors clip in no problem.
I used the oem upper green o-rings to seal the injector in the fuel rail, that's fine. The problem i'm having is with the bottom seals. As you can see the injectors came with a small black o-ring.
The intake manifold has this "cushion" ring that sits on the stock injector just fine and plugs nicely into the IM. Seen below..
Now, when I try to put the cushion on the RC injector, it fits but is stretched a little. When I try to put the cushion/RC injector into the Intake manifold, they dont fit. I've tried using oil, but no go.
Do I sand down the outside of the cushion (or inside) to make the combo fit?
Any help yould be great
Old Feb 19, 2004 | 07:33 PM
turbo96wr's Avatar
Default Re: Installing RC injectors (Blackack26)
the only thing you have to do is bring the fuel rail up some so the injector sit on top of o-ring with some slight pressure and you will not have a problem it does not need to sit all the way in the o-ring. make sure you place the o-ring in the socket all the way. 756 hp on meth. with inj..... placed just like i explained.
Old Feb 19, 2004 | 07:57 PM
Blackack26's Avatar
Default Re: Installing RC injectors (turbo96wr)
So I put the cushions into the IM, shim the fuel rail up a tad with a couple of washers and the injectors just sit on top/sightly pushed in?
Old Feb 19, 2004 | 08:15 PM
60-1teg's Avatar
yes.
Old Feb 19, 2004 | 09:22 PM
EG6owner-T's Avatar
Default Re: Installing RC injectors (2.0lhatch)
make sure you have them black washers on the 3 screws for the fuel rail so it can sit properly... i had a 94 ls
Old Feb 19, 2004 | 10:08 PM
Blackack26's Avatar
Default Re: Installing RC injectors (EG6owner)
black washers?
Old Feb 19, 2004 | 10:40 PM
Cruiser G's Avatar
yea should be like half inch plastic washers.
Old Feb 19, 2004 | 10:43 PM
Blackack26's Avatar
Default Re: Installing RC injectors (Cruiser G)
the ones that go under the cushion things on the IM?
Old Feb 19, 2004 | 11:05 PM
RAWB's Avatar
I used a dremel to bore out the inside of the seal. Go a little at a time and keep test fitting it till it goes in good, but still a bit tight. Use vaseline- it'll help
Old Feb 20, 2004 | 06:08 AM
EG6owner-T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blackack26 &raquo;</TD></TR><TR><TD CLASS="quote">the ones that go under the cushion things on the IM? </TD></TR></TABLE>
yeah but where it can bolt up the fuel rail to, not where the injectors fall in.
Old Feb 20, 2004 | 06:49 AM
Muckman's Avatar
Moderator in Chief
Try the OEM ones? if they fit.
Old Feb 20, 2004 | 07:16 AM
Chillinit's Avatar
Default Re: Installing RC injectors (Muckman)
can anyone post a pic of this please? I'm about to install my rc's aswell
Old Feb 20, 2004 | 07:28 AM
IN VTEC's Avatar
Default Re: Installing RC injectors (Chillinit)
RC310's on my Skunk2 manifold. I can gather some pics of the individual pieces later on today from the other motor. I'll also post pics of them installed with the tapered grommets instead of the OEM plastic spacer and grommet.
Old Feb 20, 2004 | 07:30 AM
Chillinit's Avatar
Default Re: Installing RC injectors (IN VTEC)
repect man...
Old Feb 20, 2004 | 10:56 AM
R THIS's Avatar
When i put in my rc's in i used some vaseline on the stock black rubber gromets, and slowly tightened the bolts that secure the fuel rail to the manifold.. they squeezed in with no problems, just took a little convincing...
Old Feb 20, 2004 | 10:59 AM
DaX's Avatar
DaX
Loved
Community Favorite
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">RC310's on my Skunk2 manifold. I can gather some pics of the individual pieces later on today from the other motor. I'll also post pics of them installed with the tapered grommets instead of the OEM plastic spacer and grommet.
Liquid filled fuel pressure gauge? That's cool...
RNPoo7
Sep 4, 2005 11:34 AM
Unjockable
Mar 26, 2005 02:50 PM
