turbo plans
Old Nov 14, 2002 | 02:48 PM
95hybridcivic's Avatar
Default turbo plans
Whats up? I am planning on putting a turbo kit on my car but I also want to beef up the bottom end with GE Sleeves JE pistons and Crower or Eagle Rods, I am also planning on a p&P job with Ferra Valves on the head. My problem is I am only going to have enought money to do the block or the turbo kit from the start then I will have to save a lil longer to do the other. I would like to know what your opinion is on this. Should I build up the bottom end first and lower the compression or should I buy the turbokit fist and do the engine next. or should I wait and do It all at once. I realize If I do the engine first that it is going to be a lil weak because of the lower compression until I get the turbo but how bad do you think it will be.
Old Nov 14, 2002 | 02:52 PM
Howitt's Avatar
Default Re: turbo plans (95hybridcivic)
its all your choice personally I would go with a rebuild first that was 10:1 compression. which should be fine for driving around the streets till you piece together your turbo kit
Dasani
Jul 5, 2006 02:39 PM
dinku27
Sep 12, 2005 05:28 AM
Doug684
Dec 30, 2003 09:59 AM
FastHonda55
Mar 3, 2003 01:57 PM
type rizzy
Aug 29, 2001 09:34 PM
